Thread: Boost gauge line location
Results 1 to 20 of 35
  1. #1 Boost gauge line location
    Banned
    Jan 2013
    Colorado
    Where is the best line to tap into in order to install a vacuum/boost gauge on an L67?
  2. #2 Re: Boost gauge line location
    Right by the map sensor
  3. #3 Re: Boost gauge line location
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Where's the map sensor? I was wondering the same because I am still planning on doing a boost gauge after I get the towers fixed
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  4. #4 Re: Boost gauge line location
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    What I did was remove my MAP and flip it upside down. I put a T off the MAP, one end coming from the port under the supercharger snout and the other end going to my boost gauge. Flipping it seemed to make sense, easier access.. lol
    MAP sensor is located back side of the supercharger above the rear valve cover behind the EGR. Google it, should be pics..
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  5. #5 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    I tried googling it. But just like the sensor for sale comes up, none on the actual car.
  6. #6 Re: Boost gauge line location
    Antioch, IL
    between the evap and T on the LIM
    2009 Challenger SRT8
    Expert at being gay.
  7. #7 Re: Boost gauge line location
    I win at bing, google sucks.
    Number 7.
  8. #8 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    So I need to pull that off then put my T fitting in that?
  9. #9 Re: Boost gauge line location
    Put your hand under the SC snout. Got the vacuum line, good.. now..put a t into that anywhere and run your gauge hose to it.
    Quick, easy, done.
  10. #10 Re: Boost gauge line location
    Nov 2009
    Tennessee
    Just an idea...
    Vacuum line off to the right of the map is going to my boost gauge.
  11. #11 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    Thanks bill, the vacuum reading only goes down to about 10 or 11. Is that normal?
  12. #12 Re: Boost gauge line location
    Nov 2009
    Tennessee
    Vacuum for a stock motor should be around 20ish in/hg. Larger cams pull less vacuum, like my XP I see 15 in/hg... 10 or 11 seems LOW for vacuum at idle...
  13. #13 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    I'll take a picture of my tapping into the line but I've done plenty of vacuum gauges before so it should work.
  14. #14 Re: Boost gauge line location
    It depends on what your gauge is reading. If you got a pound gauge, then 10 is about right. If it's in hg, then it should be nearly 20
  15. #15 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    It's in HG, here is a video of the gauge in action.
  16. #16 Re: Boost gauge line location
    Nov 2009
    Tennessee
    If it's in HG then at idle it should be around 20ish. And after you've gotten off the accelerator it should dip lower then that, say 25ish, and back up to 20. When you stopped it looked like the gauge stopped at 10 and did not go any lower. (also the gauge is jerky in the vacuum area, seems to work smooth in the boost area) Might be a faulty gauge? I doubt you have a vacuum leak, you'd feel that...
  17. #17 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    It's a brand new gauge.
  18. #18 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    An old sunpro gauge I have reads the same way.
  19. #19 Re: Boost gauge line location
    Banned
    Jan 2013
    Colorado
    Boost line T-fitting.
  20. #20 Re: Boost gauge line location
    Something is wrong if you only see -10in/hgs of vacuum.
  1. A/C low pressure line location on 98 GTP
    By Juanmiguel in forum General Tech Discussion
    Last Post: 02-26-2010, 10:02 PM
  2. Whats the best place to run a boost gauge vacum line??
    Last Post: 09-25-2009, 10:16 PM
  3. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 03:18 PM
  4. T-Fitting for my vacuum line & boost gauge.
    By DnaProdigy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-05-2009, 02:36 PM
  5. Boost Gauge and vacuum line
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 12:58 PM
