Thread: Spark plug replacement
Results 1 to 6 of 6
  1. #1 Spark plug replacement
    Dec 2012
    Lowell
    I'm replacing my spark plugs and wires in the morning, does anyone know the best way to get at 2 4 and 6? Do I take anything off to make it easier?
  2. #2 Re: Spark plug replacement
    Depends if you are a bigger guy or a smaller guy.
    I just stand on the passenger side and reach down over the alternator and get them that way. Some people lay on top aswell.
    But to give yourself and extra 1-2 inches, unbolt the 2 front motor mounts, aka the dog bones, then hook a ratchet strap to the alt brace bar or engine pull bracket from somewhere on the core support or something and pull the motor forward.
  3. #3 Re: Spark plug replacement
    Feb 2013
    37.295091, -121.930053
    You should be able to remove them without moving the engine.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Spark plug replacement
    As far as you know are they the original plugs and do they still have the little metal boots around them? If they do you'll probably need to do what FiveFinger suggested if they don't you should be able to reach them if not on the passenger dogbone bracket there's a extra slot that allows the motor to move forward about a inch or so.
    04 Comp G.
  5. #5 Re: Spark plug replacement
    Dec 2012
    Lowell
    I did it! I ended up taking off the coolant reservoir and my Otto racing strut brace to get some extra room... I have all new auto lite plugs and 10.5 mm wires and still have a misfire on cylinder 1.. Is my next step to replace the coil packs? If it is should I spend the extra money on the high voltage ones?
  6. #6 Re: Spark plug replacement
    Swap the coil around, see if the misfire follows.
    And no, the stock coils are the only coils you should run.
  1. Spark Plug ?
    By reno in forum Introductions/Noob Questions
    Last Post: 07-12-2013, 08:40 PM
  2. spark plug gap?
    By jman44 in forum Introductions/Noob Questions
    Last Post: 06-04-2013, 05:52 AM
  3. Spark Plug Gap
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 10-14-2012, 09:57 AM
  4. Spark plug gap?
    By 91z in forum General Tech Discussion
    Last Post: 04-20-2011, 08:28 PM
  5. Spark Plug Replacement??
    By LuckyBambu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 08:06 PM
