Thread: e85 Dyno Tune at Dyno Tune Motorsports - Video
Results 1 to 20 of 28
  1. #1 e85 Dyno Tune at Dyno Tune Motorsports - Video
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Here is a video of the last pull on the dyno. We installed a 2.8 and ended up with 277 wheel horse and 392 max torque.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  2. #2 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Would have expected the number to be higher.
    Same setup in my sig with SIX cam was 328whp/401wtq.....and that was on a 2.8 pulley also. Same exact setup on 93 was able to do 277whp/348wtq
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    392 lb ft. is a decent number for sure.
    Would of expected the whp to be a tad higher though.
  4. #4 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Apr 2011
    Columbus, OH
    wtq is not and accurate representation because of converter flash. The converter is not locked during the dyno pull. whp is what you need to focus on.
  5. #5 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Mullet Member Wotgtp's Avatar
    Connecticut
    2.8 on a gen 3? It seems low to me as well. On a 3.4 With headers/tune/intake/rockers I made 248whp.
  6. #6 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Washington Michigan
    Quote Originally Posted by GMR Badass View Post
    My numbers are just about 340 at the crank which is 100 more hp than stock and I'm fine with that. I'm running a stock trans and the car seems fast enough for me for the time being. I want to keep the trans in one piece this year and I'll work on the trans and blower this winter. It's a work in process ya know? Brian did tell me I could pick up a lot more power with a cat back and a ported blower/LIM. I didn't post this video to brag about how much power my car has but just to share with some of my forum friends the progress of my car.
  7. #7 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Apr 2011
    Columbus, OH
    Don't get me wrong, it's a fun ride at that whp range. Just expected the numbers to be a little higher. I have GenV and SLP catback on that car. Skip ported blower and ported LIM. Those numbers I put down were with the GenV and untouched motor except injectors and valve springs.
    I also was on stock trans......for a while. At 330whp on stock trans the clutches started going and ended up going with a TEP trans in the end.
  8. #8 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    I saw this on fb earlier today. I'll be visiting brian soon if I ever get off working 7 days a week
  9. #9 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    This makes me want to get my cam installed
  10. #10 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Do it!!!
  11. #11 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Time and money Smutty time and money.
  12. #12 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Connecticut
    I'm not poking fun of your car, I'm just saying it should be higher and something may not be working like it should.
  13. #13 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Feb 2009
    flintnasty MI
    If you have a cam and race gas and make < 340whp something is wrong.
  14. #14 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Washington Michigan
    Maybe the dyno is not calibrated the same as the one other people use idk but the car feels a ton fast to me. I will have to get some track times some day and see...
  15. #15 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Max Cook
    Guest
    Could be your torque converter getting sloppy and dumb. That happend to me and Zach Brunsink. He changed his torque converter from a sloppy 3k stall to a new stock gt one and picked up 50WHP on the dyno. I haven't re-dyno'd mine since replacing mine since Im gonna be doing e85 dyno tune later this year but its probably the same thing.
  16. #16 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Oct 2012
    West Springfield
    Quote Originally Posted by tms8582 View Post
    His type of dyno can't be re calibrated.
    Sounds like something else is wrong.
  17. #17 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    << waits for the time slips dyno # are begging to bring in the haters time slips on the other hand will shut em up just sayin.........
  18. #18 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Cambridge, Ontario Canada
    Cat clogged? Keeping HP back but TQ good? Any KR?
    2005 E55 - stock
  19. #19 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    GTP Level Member AjL227's Avatar
    IL
    Nice numbers. I can't wait to get my 2.6 car dyno'd with the corn.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  20. #20 Re: e85 Dyno Tune at Dyno Tune Motorsports - Video
    Quote Originally Posted by Max Cook View Post
    I can't see how a converter can get sloppy short of failure, and that typically takes out other components with it.
    Changing from a higher stall to a lower stall will increase HP to the wheels because it's more efficient.
  1. Intense dyno tune
    By PontiacL32 in forum PCM Tuning
    Last Post: 12-17-2012, 11:03 PM
  2. nor cal dyno tune
    By 90cobraclone in forum West
    Last Post: 04-13-2012, 03:28 PM
  3. dyno tune disaster
    By 707chance in forum Track Sessions and Kills
    Last Post: 07-12-2011, 01:05 PM
  4. anyone get a dyno tune from ZZP?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-17-2009, 04:53 PM
  5. My Dyno Tune
    By Keifer in forum General Tech Discussion
    Last Post: 07-15-2008, 07:12 AM
