Thread: Why doesn't my car like ZZP plug wires?
Results 1 to 12 of 12
  1. #1 Why doesn't my car like ZZP plug wires?
    SE Level Member 92bird's Avatar
    Colorado
    I've tried running their 10.3mm wires, and the car misfired under boost so I exchanged them for a set of their new 10.5mm wires. Now the car will barely even idle. I triple checked the cylinders and they are all hooked up correct, plug wires clip on nice and tight both at the spark plug end and coil pack end. I was impressed at how nice and positive then clipped on actually.
    So I remove them and toss a worn out 30k miles set of autolite professional series stock replacement wires back on and it runs perfect..
    Do the bigger wires require a stronger coil or do ZZP wires just suck?
    My ICM is new, and I tried the coils and ICM off of another car. Same result. Stock wires work fine, ZZP wires the car doesn't want to run smooth at all.
    I'm just wondering if there is a problem with my ignition system, and maybe the lower resistance wires are causing the problem to surface.
    Thanks for any ideas..
    2000 GTP: ZZP Z7 turbo kit,Precision 5858cea Billet turbo,F&R p-logs,L26 upper/lower,HV3 insert,60lb inj,L67 Throttle/MAF,1.95 Yella Terra rockers,PAC 105 springs/titanium retainers,3" exhaust,full suspension,Self-built 4t65e with zzp 300m input shaft, TEP 7/8" 2.93 chain set, blue plate clutches,PI 2800 stall billet cover converter
  2. #2 Re: Why doesn't my car like ZZP plug wires?
    I have heard that ZZP wires are hit and miss sometimes. I would just contact zzp and let them know that you are having issues.
  3. #3 Re: Why doesn't my car like ZZP plug wires?
    I've heard of people having issue with ZZP wires, the stock wires are the best.
  4. #4 Re: Why doesn't my car like ZZP plug wires?
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    Prj wires FTW!!
    If You Cant Hear The Whine You're Too Far Behind...
  5. #5 Re: Why doesn't my car like ZZP plug wires?
    Colorado
    I emailed ZZP and zoomer replied that I am the first to have a complaint about their new 10.5mm wires.
    I am going to double check them on a friend's completely stock GTP tonight, to rule out any problems on my end first before trying another set.
  6. #6 Re: Why doesn't my car like ZZP plug wires?
    Max Cook
    Guest
    ZZP's first massively oversized wires were awesome. then they got a different supplier that was complete rubbish and they were horrible for a long time until they went back to their old supplier which I think was like last year. They should be good again. It's still not impossible you got a bad set though.
  7. #7 Re: Why doesn't my car like ZZP plug wires?
    SE Level Member SLICK98's Avatar
    Jul 2010
    erie,pa
    My new taylor wires worked great
    1998 GP Daytona Supercharged
    1989 GP SE Daily driver
  8. #8 Re: Why doesn't my car like ZZP plug wires?
    SWPA
    I highly doubt you have any need for wires that large. I know plenty of people making north of 500, 600 and even 700 hp on 8mm wires.
  9. #9 Re: Why doesn't my car like ZZP plug wires?
    GTP Level Member AjL227's Avatar
    IL
    Stock is great, PRJ if you want to spend the money.
    Return those ZZP wires and demand a full refund.
    I did that after having them for two years and they paid up full.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  10. #10 Re: Why doesn't my car like ZZP plug wires?
    The only reason I went for larger wires was the insulation factor. Running them in tight areas and under the snout etc.. That's where arcing would occur. Larger wires mitigate the issue. Other than that.. why run them?
  11. #11 Re: Why doesn't my car like ZZP plug wires?
    Slower, Lower Delaware
    Same here, and I got a deal on mine, they're Moroso. I'm not sure they didn't fall off the back of a truck.
  12. #12 Re: Why doesn't my car like ZZP plug wires?
    Dec 2011
    Orlando, FL
    i have MSD 8.5mm wires and had the same problem. then i realized i had mistakenly crossed two of the wires. corrected the issue and never had a problem since. simple problem, simple solution. just check and make sure you ran them correctly.
    2004 GTP
  1. MSD plug wires?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-25-2013, 05:39 PM
  2. Best plug wires??
    By reallyfast1 in forum 04+ Specifics
    Last Post: 06-06-2010, 07:34 AM
  3. Plug Wires?????
    By 2k6GT in forum General Tech Discussion
    Last Post: 08-10-2009, 08:42 AM
  4. Plug wires
    By 04muscle in forum General Tech Discussion
    Last Post: 03-09-2009, 01:02 AM
