Thread: zzp flex
Results 1 to 4 of 4
  1. #1 zzp flex
    Mar 2013
    amherst
    On my stock sd headers the flex is almost sitting in like cups on either end. And I bought a zzp 3' flex and it doesn't have this cup or end holders do I need to buy something else or can I use it as it is ?
  2. #2 Re: zzp flex
    I live here. DirtDog's Avatar
    Jun 2012
    Should be able to cut old on out and weld new in
  3. #3 Re: zzp flex
    May 2008
    Schuyler, NE
    I would recommend buying new v-bands. The clamp they give you with the headers, kind of sucks. I would get a new one, since you're going through the work to replace it. And, I would put a v-band on both ends so it makes removal and installation of the rear header a lot easier.
  4. #4 Re: zzp flex
    ZZP flex welded on.
  1. flex plate
    By Eric Whitter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-31-2013, 09:52 PM
  2. ZZP flex pipe
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-12-2011, 06:25 AM
  3. Need gtp flex joint.
    By Dirt Diggin GTP in forum Introductions/Noob Questions
    Last Post: 08-09-2010, 11:06 AM
