Thread: Crank position sensor
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
  1. #1 Crank position sensor
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Ok I've been told one I replace my crank sensor I'll have to get it relearned or something like that,is there anything I can buy to do it at home,some say you do it with a obd scanner with something built in it,I'm not to sure,I need some help
  2. #2 Re: Crank position sensor
    Jul 2010
    *once
  3. #3 Re: Crank position sensor
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I was told that when I dropped my motor in my car. I used the low mileage L26 crank sensor with my fresh tune. I was quite surprised when I turned the key and my car fired right up. LOL I'm not sure what constitutes a "relearn". IIRC and I'm not confused about the VATS system (or passkey thing whatever it's called, I have to many cars) I think it's something you can do without a tuner???
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  4. #4 Re: Crank position sensor
    Jul 2010
    Here's what video I watched http://youtu.be/40VN5j1xc3A
  5. #5 Re: Crank position sensor
    Jul 2010
    He says it has to be
  6. #6 Re: Crank position sensor
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I've done a few crank sensors on 3800's and never done a case learn.
  7. #7 Re: Crank position sensor
    Jul 2010
    And it ran perfect?
  8. #8 Re: Crank position sensor
    Quote Originally Posted by 231FUN View Post
    same here...ran fine.
    04 Comp G.
  9. #9 Re: Crank position sensor
    Jul 2010
    Ok good,what did y'all make to hold the pulley in place so it didnt move while you undid the bolt
  10. #10 Re: Crank position sensor
    It's a bit more to it then that but to make it easier ill just link ya
    http://www.grandprixforums.net/how-r...sor-60906.html
    If you don't have a good impact gun and compressor and can get a set of vicegrips and attach them tightly on the flexplate and then use a breaker bar to break the bolt loose.
    04 Comp G.
  11. #11 Re: Crank position sensor
    Jul 2010
    Ok I'm buying a harmonic balancer puller for gms,it says for 3800 will it work with 3400 and 3100 to??
  12. #12 Re: Crank position sensor
    Nov 2009
    Tennessee
    Not to ask a stupid question, but what motor do you have?
    I know it's the supercharged section, but I goofed up and posted in the wrong section yesterday so it happens.. LMAO
    What you will need (you'll have to look at the thread linked above) and get the right bolts to use for the puller. I believe they are M6x1.00??? maybe 75 - 80mm long with washers so the head of the bolts will not slide through the puller openings.
    Also, research how to use your starter to break your bolt loose. I have never used this method, but I have heard about it. I personally wouldn't do it do to breaking something, but if others have tried it would be easy.
  13. #13 Re: Crank position sensor
    Quote Originally Posted by 94grandprix View Post
    why would you do that when you can spend $20 rent the one from autozone and then get refunded back your $20 when you return it o_O unless you like spending money.
    OEM/Harmonic balancer puller kit (27019) | Harmonic Balancer Puller | AutoZone.com
    04 Comp G.
  14. #14 Re: Crank position sensor
    Nov 2009
    Tennessee
    ^^^ x2, rent the puller and buy the right bolts... you'll be out $4 at most overall...
  15. #15 Re: Crank position sensor
    Jul 2010
    The harmonic balancer on the 3100 is coming off slightly and what money I was going to use is in my pay pal plus I may need it but would just any pulley remover work with it cause I got one from advance when I replaced my power steering pump but I think I may have misplaced it
  16. #16 Re: Crank position sensor
    Nov 2009
    Tennessee
    I bought this one years ago and have used it many times.
    Performance Tool W151P - Harmonic Balancer Puller | O'Reilly Auto Parts
    Just get it at your local parts store and go to a hardware store and get the right bolts (3 bolts less then $1 a piece) and a handful of washers.
    The power steering pump pulley puller is something totally different... And if you are feeling really ambitious you might want to change out the front seal, you'll be right there.
  17. #17 Re: Crank position sensor
    Jul 2010
    I'm kinda of a nooby lol but learning but what kind of seal?
  18. #18 Re: Crank position sensor
    Jul 2010
    Oh and will a bad sensor cause my rpm hand not to work?
  19. #19 Re: Crank position sensor
    Nov 2009
    Tennessee
    The front main seal is what the balancer slides into. It seals so oil doesn't leak. I was suggesting it because you will be right there, you'll just have to remove the old one and tap in a new one before you put things back together. (I'd get a GM one, they are like $16 at most I believe.) You can leave it alone, but if you have high mileage and start fooling with it by sliding the balancer on and off it might not seal back up properly... I just always have preventative maintenance on my mind..
    And yes if I remember correctly a crank pos sensor going out will cause your RPM hand not to work.
  20. #20 Re: Crank position sensor
    Jul 2010
    Ok my car has 197000 miles so I'll put one in while I'm down there
  1. Replacing the crank position sensor
    By Pat Grindharderthenyou in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 11:43 AM
  2. New guy from SD, Crank position sensor help.
    By Mak90 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-15-2012, 09:14 AM
  3. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  4. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
