Thread: To mod, or to rebuild? That is the question.. The $2000 question
Page 4 of 4 FirstFirst ... 234
Results 61 to 71 of 71
  1. #61 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Quote Originally Posted by comatoast View Post
    all you need is the zzp block off plates for the delete correct?
    No
    You also need....
    Wait for it....
    Copper rtv and a penny and nickel aka some change. Once you remove the egr u rtv either a penny or nickel over the hole (whichever fits better) then rtv the block off plate over it. I kno very expensive.
    04 Comp G.
  2. #62 Re: To mod, or to rebuild? That is the question.. The $2000 question
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    hmmmm.. hmm
    How to? I can picture it, kind of.. But sounds ghetto
  3. #63 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    also if you take out the stock airbox, is there anywhere to place the pcm?
  4. #64 Re: To mod, or to rebuild? That is the question.. The $2000 question
    You won't see the change it goes underneath the block off plates and just helps to seal the egr holes. Cheap and very effective.
    It will stay in place no need to mount the PCM unless you want to and you can just use a few zip ties to keep it held down.
    04 Comp G.
  5. #65 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    thanks again for all the help man.. Its just that one clip holding the pcm to the airbox, right?
  6. #66 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Emm I believe so I don't remember exactly its been 5 years or so
    04 Comp G.
  7. #67 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    lol, thanks
  8. #68 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Nov 2012
    MN
    I wouldn't rebuild unless you had a actual reason to rebuild. If your motor is running fine now...just slap the mods on it and keep on trucking. These motors are a beast and mileage wouldn't scare me.
    Do you have any pics of your header install? Either I'm an idiot or can't find any pics. Especially 04+ just trying to see how people worked the trans stick , the ac lines and what needed to be done with the radiator fan motor.
  9. #69 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Probably the only one I took. I like to dive in and complete **** lol so I'm not much of a picture taker
    04 Comp G.
  10. #70 Re: To mod, or to rebuild? That is the question.. The $2000 question
    Remove the trans dipstick should be one 10mm holding it. Will leak a little bit of trans fluid out and once you get he read header attached use a extension and add it back. Ac lines you literally just grab a rag and you some muscle and slowly push if down. Then throw the front header on and make sure there's clearance.
    04 Comp G.
  11. #71 Re: To mod, or to rebuild? That is the question.. The $2000 question
    I didn't have to pull my trans dipstick at all. I just got everything bolted up and bent it a little where it was touching.
  1. 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2013, 01:24 PM
  2. Caliper rebuild question
    By Logan541 in forum General Tech Discussion
    Last Post: 10-27-2012, 03:55 PM
  3. Pre-Branson Rebuild Question
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 04:00 PM
  4. question on Fbody caliper pistons rebuild
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2008, 12:08 PM
  5. Tranny rebuild question
    By bula81069 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2008, 05:57 PM
