Thread: Wide Band 02 Display (not a Round Gauge)
Results 1 to 5 of 5
  1. #1 Wide Band 02 Display (not a Round Gauge)
    SE Level Member blackgtp95's Avatar
    Jun 2011
    Toledo,OH
    I am in need of a wideband kit/gauge that is flush mount or something besides the standard 2 1/16" gauge (I have no place to mount another round gauge)
    The only thing that I can find that is not a round standard gauge is this DB Gauges: Air Fuel Ratio Guage the major problem I have with this is the fact it can not do serial data (no logging)
    If anyone else knows of a Wideband Gauge that is similar to the one linked above let me know
  2. #2 Re: Wide Band 02 Display (not a Round Gauge)
    Jan 1970
    Maquoketa, Iowa
    I use a PLX M300
  3. #3 Re: Wide Band 02 Display (not a Round Gauge)
    NGK AFX are a square gauge I think.
  4. #4 Re: Wide Band 02 Display (not a Round Gauge)
    Jun 2011
    Toledo,OH
    Quote Originally Posted by FoSHO99 View Post
    I use a PLX M300
    This says it has the feature to run as the factory narrow band at the same time the wideband is functioning is that how you have yours hooked up? It also specifically states E85 which is what I am doing (not that that really matter I don't think)
    http://www.plxdevices.com/AppNotes/PLXApp004.pdf
    If that is how it works that's pretty slick not having to add a bung and run even more wires
  5. #5 Re: Wide Band 02 Display (not a Round Gauge)
    If you already have an aeroforce...just feed that.
  1. Hooking up NGK AFX Wide band to HPtuner
    By TheOtherNick in forum How To Write-Ups/Tech Tips
    Last Post: 05-14-2013, 11:16 AM
  2. Gtp meth etc wide band question.
    By ctspoolintsi in forum PCM Tuning
    Last Post: 06-28-2012, 11:54 PM
  3. Wide Band Question
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-16-2009, 06:50 PM
  4. Good Wide band
    By TheOtherNick in forum General Tech Discussion
    Last Post: 05-24-2009, 01:00 AM
