Thread: hissing sound before shifts
Results 1 to 10 of 10
  1. #1 hissing sound before shifts
    GT Level Member des19's Avatar
    May 2011
    Ontario
    04 gtp comp g 70k miles.
    I have no clue what this issue could be. Not even sure if its a problem but i am getting this slight hissing sound almost as if there is a leak somehwre right before shifts (for about 3 seconds you hear it). Also it will only do this with a very light foot on the gas (will not hear the sound at all accelerating harder).
    No performance issues just sound i don't think is supposed to be there. Any ideas?
  2. #2 Re: hissing sound before shifts
    May 2011
    Ontario
    also will only do sound while driving and for 2-5 seconds before a shift around 3000 rpm
  3. #3 Re: hissing sound before shifts
    May 2011
    Ontario
    bump would like to hear what people think
  4. #4 Re: hissing sound before shifts
    I think it's odd. Really really odd.
    Beyond that, I have no idea. Unless it's rpm related, which it sounds like it is.. but what is the question you are asking.
  5. #5 Re: hissing sound before shifts
    May 2011
    Ontario
    I am just asking what some people think it may be. Don't think it's directly related to rpm change but rather related to before a shift. It will make a slight higher pitch whine/whistle sound before shifting. Again only on a light foot on the pedal
  6. #6 Re: hissing sound before shifts
    Well..based on the lack of responses, I'd say folks didn't have enough info/clues to give you a guess. That's why I waited until you bumped it. Can you get a vid or give us any more consistency or info about it?
  7. #7 Re: hissing sound before shifts
    St. Louis
    OP- do you have a cone filter on your car or stock airbox? I know on my GT I can hear a slight hiss when it shifts 1-2 if I'm light on the throttle buy that's normal to me. Done it the whole time I've owned it. No issues either. I usually just ignore it. No CEL= keep on driving
    Is the sound coming from inside the car, or oustside?
  8. #8 Re: hissing sound before shifts
    May 2011
    Ontario
    Quote Originally Posted by FordMan77 View Post
    i do have a k&n cone filter on and now that I think of it, may only be between 1-2 shifting. But it is loud. If some one else is getting the sound, it must be normal. I will actually post a video but it may be hard to get the sound on tape. Also it is definately not from inside the car, sounds like its coming front engine for sure actually by the intake area.
  9. #9 Re: hissing sound before shifts
    May 2011
    Ontario
    To describe the sound better it is like a high frequency pitch almost like a dog whistle but you can hear it before shifts. I tried taking a video and couldn;t get the sound for more than a split second. No point in posting the vid can't hear it. Can't get the sound unless car is very warm i think. Anyways don't think its an issue.
    thanks for input
  10. #10 Re: hissing sound before shifts
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Try swapping back to the stock intake and see if the sound goes away. I have ridden in several vehicles with CAI or just an open cone and they all make different noises. One even made a whistle sound at a certain throttle. It could just have to do with the airflow right before the 1-2 shift.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  1. Hissing sound coming from rear speakers.....
    By p coico in forum Audio, Security & Visual Electronics
    Last Post: 01-20-2013, 02:46 PM
  2. HELP! Hissing sound after drilling though firewall
    By Jomamma in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2012, 11:26 PM
  3. Hissing noise?
    By LuckyBambu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2011, 10:53 AM
  4. Hissing noise at the Firewall
    By darkfox1009 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2011, 04:43 PM
  5. Brakes make a hissing sound
    By supercharged98 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2010, 09:09 PM
