Thread: YT 1.8 roller rockers on stock springs?
Results 1 to 12 of 12
  1. #1 YT 1.8 roller rockers on stock springs?
    Jan 2013
    Australia
    engine has 110.000 miles (~170.000km) on it
    yay or nay?
  2. #2 Re: YT 1.8 roller rockers on stock springs?
    Omaha, NE
    Yay mate.
    ZZP's site even says their 1.9s "work with all stock or aftermarket pushrods, lifters, springs, retainers".
    ZZPerformance - 1.9 Ratio Modified Rockers #ZZ-19MR
  3. #3 Re: YT 1.8 roller rockers on stock springs?
    GTP Level Member AjL227's Avatar
    IL
    I mean...I would get 90# or higher but that is just me.
    Cost of springs < cost of engine
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  4. #4 Re: YT 1.8 roller rockers on stock springs?
    Jan 2013
    Australia
    cheers cobber
    to be honest ive never understood the whole "1.9 modded rockers are ok on stock springs, but YT rollers aren't" thing...
    The YT aluminium rockers are much lighter than the steel modded ones... so the spring has less resistance/inertia to work against, which would mean less chance of valve float with YT roller rockers, right?
  5. #5 Re: YT 1.8 roller rockers on stock springs?
    Omaha, NE
    roller rockers arent worth the gain.
    i ran modded 1.9s on stock springs forever and would recommend that if youre going the rocker route.
    Many have done 1.8s and 1.9s on stock springs without ever having issues.
  6. #6 Re: YT 1.8 roller rockers on stock springs?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    You could, But I don't know why you would for the price you might as well while you are in there and have it all apart it's only another 15 minutes or so on the project.
  7. #7 Re: YT 1.8 roller rockers on stock springs?
    Feb 2009
    flintnasty MI
    1.8 rockers are no better than stock.. I ran them for years on a 18psi turbo setup without floating.
  8. #8 Re: YT 1.8 roller rockers on stock springs?
    Slower, Lower Delaware
    I wouldn't recommend something because some have done it "without ever having issues."
  9. #9 Re: YT 1.8 roller rockers on stock springs?
    Omaha, NE
    Quote Originally Posted by Sudden View Post
    First off, don't half ass quote me, I said many. You don't realize that rockers aren't a big deal. Without a cam in addition to rockers lift isn't changing much at all.
  10. #10 Re: YT 1.8 roller rockers on stock springs?
    ooh!, touchy. And I consider .080 a substantial increase in lift on a stock spring that already has many miles on it. It's not a cam but it can get you 20 HP. If you've ever broken a spring you can see the value of replacing them, plus the value of just having springs that do the job right.
  11. #11 Re: YT 1.8 roller rockers on stock springs?
    May 2008
    Schuyler, NE
    You aren't getting .080" extra lift by switching to 1.8 RR's.
  12. #12 Re: YT 1.8 roller rockers on stock springs?
    No, that would probably take 1.9s. But you are still pushing possibly fatigued springs faster and farther than they are used to.
