Good morning. I would like to get some input on my Vacuum at idle. I have just completed a Top Swap w/full rebuild and installed a ZZP VS cam, LS7 lifters, Stock length ZZP OR push Rods and LS6 Valve springs. I have sent the piston and connecting rods from my L26 to get reconditioned and put on new rings. So fare i have driven almost 40 miles on the motor and my Engine Vacuum at idle is 13.5 to 14.5 at idle and dances between 13 and 14 constantly. DOes not stay steady. the heads are off a L32 and were rebuilt and cleaned at the machine shop.
COuld i have not timed it properly? If i didnt then i am a absolute retard because it is very simple. Do i probably have a valve hanging open? do i have low compression? Or maybe my Rings are not properly seated yet.
Any suggestions!!!!
Thanks!
