Thread: 06+ valve covers?
Results 1 to 5 of 5
  1. #1 06+ valve covers?
    Sep 2011
    Omaha
    I've heard that the 06+ valve covers are different and don't leak as much, also they are black, is this true?
    3.5 in" pulley, zzp dp, custom hai, colder plugs, red wires- red means fast, Tog headers, resonater Delete, custom dyno tuned and max out injectors...
  2. #2 Re: 06+ valve covers?
    Pretty sure they are the same other than color.
  3. #3 Re: 06+ valve covers?
    Sep 2011
    Omaha
    Right on, thank you sir!
  4. #4 Re: 06+ valve covers?
    SE Level Member sco77's Avatar
    MD
    The only thing that would make the newer style one not leak is a better gasket or the fact that it's just newer. You might be thinking about oil pans, the newer aluminum oil pans dont have the issues of the stamped steel ones.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  5. #5 Re: 06+ valve covers?
    Aug 2012
    SE Wisconsin
    Yeah I literally just did my rear about 2 hours ago on my 03 GTP. When looking for gaskets i found that they fit pretty much all years; so i'd say they are the same other than being a different color.
  1. zzp valve covers
    By rodman in forum Turbo
    Last Post: 08-30-2009, 04:20 PM
