Thread: Cam install tips?
Results 1 to 20 of 35
  1. #1 Cam install tips?
    May 2012
    Where winter never ends
    Going to be installing a cam next weekend. Any of those "life-saving/time saving tips" from people who have done it would be appreciated!
    2000 Regal - Winter Beater
  2. #2 Re: Cam install tips?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Is the motor out of the car? It can be done from the passenger side wheel well but I did mine when the motor was out. Here is a good write up to read Cam installation L67 - TECH - 3800Pro.com Forum
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: Cam install tips?
    May 2012
    In the car. Going through the wheel well. I have read the writeups. Just looking for tips and what not. Preferably on how to not break something or score a bearing
  4. #4 Re: Cam install tips?
    GTP Level Member
    Sep 2011
    Motown
    it would be alot easier to just pull the motor to be honest. Then you can clean it and the engine bay up a little bit. But that is just my opinion.
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  5. #5 Re: Cam install tips?
    May 2012
    Quote Originally Posted by Classy Pontiac View Post
    I know, I just dont have the room to do that. And I Really dont want to pull the motor.
  6. #6 Re: Cam install tips?
    Use assembly lube when sticking the cam back in the motor. Like cover the cam in it.
  7. #7 Re: Cam install tips?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    lots and lots of lube.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  8. #8 Re: Cam install tips?
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    you DONT NEED TO PULL THE MOTOR. So not necessary. Just unbolt the cradle on the pass side and drop her down. Make sure you disconnect the int steering shaft. Use prelube on the cam, and dont be shy with it. While your at it, get rid of the balance shaft gear.
  9. #9 Re: Cam install tips?
    May 2012
    Quote Originally Posted by danomite02 View Post
    This is the method I was going to use.
    For lube does this work: Auto Racing Products 100-9910 - Assembly Lube | O'Reilly Auto Parts ?
    Also, why do I want to remove the balance shaft gear?
  10. #10 Re: Cam install tips?
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Balance shaft becomes obsolete when you install a performance cam. I have read that it can actually cause vibrations at higher speeds that can hurt your engine. The gear was removed on mine when the cam was installed and have had zero problems
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  11. #11 Re: Cam install tips?
    Sep 2011
    palm harbor florida
    should you get rid of the gear even wiht a vs cam?
  12. #12 Re: Cam install tips?
    Washington Michigan
    I have not heard about the balance shaft causing any problems with a mild cam. When I did my motor I removed it altogether however. I've read removing it can gain a few hp's and release some rotational mass. My motor does idle rough (which is going to happen with a bigger cam) and you can hear the bigger cam for sure but I don't notice the balance shaft missing otherwise. Seems like removing it a personal preference from my research, I've heard arguments both ways. I'd probably take out the gear personally if your really after getting the most from the cam upgrade.
  13. #13 Re: Cam install tips?
    May 2012
    Alright will do. But what lube should I buy lol.
    This stuff?
  14. #14 Re: Cam install tips?
    No that's the stuff to use on bolts. You need
    Sealed Power® 55-400 - Camshaft Assembly Lube | O'Reilly Auto Parts
  15. #15 Re: Cam install tips?
    Jul 2011
    CT
    i used GM camshaft/lifter prelube GM #12345501
  16. #16 Re: Cam install tips?
    Sep 2011
    palm harbor florida
    Ultra Slick Engine Assembly Lube Permatex 81950 Free Shipping | eBay
    this stuff is amazing super sticky and thick
  17. #17 Re: Cam install tips?
    May 2012
    Three options. Which one do I buy :P?
  18. #18 Re: Cam install tips?
    Willoughby, Ohio
    take your time on the thrust plate torx bolts...thery are shallow, dont strip them, and dont loose the cam interrupter magnet or the cam key, they are small...and yes i learned the hard way
  19. #19 Re: Cam install tips?
    torx bolts are t27 so if you don't have one go get a nice quality bit.
  20. #20 Re: Cam install tips?
    GT Level Member glendayle's Avatar
    Salt Lake City
    It's a t30.
    Sent from my SPH-D710 using Tapatalk 2
    1999 Regal GS Mods-180 tstat; CAI FWI; ubend delete/3"DPCB PLOG; HID fog conversion, 3.5, tint(42%/20%), TK Trans 3.29 gears
  1. eibach install tips
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 06-08-2013, 09:50 PM
  2. Header Install Tips?
    By ImColeTrickle in forum General Tech Discussion
    Last Post: 03-08-2012, 09:09 AM
  3. cam supporting mods/install tips
    By 05SS45 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 10:34 PM
  4. Any tips or tricks for GMPP sway bar install?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 09-13-2009, 10:08 PM
  5. Blower install tips, hints.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2009, 09:05 PM
