Thread: Ignition will not go back to off position
Results 1 to 10 of 10
  1. #1 Ignition will not go back to off position
    GTP Level Member buickman104's Avatar
    NYC
    Once in a while (becoming more frequent) when I shut the engine off the ignition will not allow me to click the ignition switch to the off position as if I had turned the engine off while still in drive, not park. I would turn the ignition switch to run and play with the shifter rowing through gears try again and try again until finally the ignition switch would allow me to click it to OFF.
    Eventually I realized that it had nothing to do with the transmission gear select because when the ignition acted up I would be able to turn it to OFF by just playing back and forth with my ignition and not touching the shifter at all. My car has well over 200k and is city driven so I guess something is worn and needs to be replaced. Any ideas or suggestions as to what needs to be replaced (aside from the whole car?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Ignition will not go back to off position
    Try pulling the little cover off the bottom of your steering column. The one that lets you release the key when the shifter release doesn't do it's thing. Because technically it actuates a soleniod in the column. If pushing that button in there always releases the key.. stuff a small piece of vacuum hose in there and smile...free repair.
  3. #3 Re: Ignition will not go back to off position
    NYC
    The key lock mechanism has never worked and I could always pull the key out even with the engine running. By having that button pushed will it also allow me to defaultly turn the ignition back to the off position too?
  4. #4 Re: Ignition will not go back to off position
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    Yes, I have the button on mine zip tied so it always works as well
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  5. #5 Re: Ignition will not go back to off position
    NYC
    Thanks. I will give it a shot!
    One more ZIP TIE added to holding the Millennium Falcon together!
  6. #6 Re: Ignition will not go back to off position
    Lemme put it this way..that new shifter I did. I haven't hooked up any electrical except the light to it. In the meantime I did what I suggested you do.
  7. #7 Re: Ignition will not go back to off position
    Just try it.. worse case is you are out a small piece of vacuum tube that you had Enrique (cause he liked my post) steal for you.
  8. #8 Re: Ignition will not go back to off position
    NYC
    Good point I will try it this 4 day holiday weekend I have coming up!
  9. #9 Re: Ignition will not go back to off position
    NYC
    Thanks for the advice the button worked like a charm! Now on to my other summer problem, A/C!
  10. #10 Re: Ignition will not go back to off position
    That's gonna take a bit more work.
  1. Key coming out of ignition..in any position.
    By chicagochuck in forum General Tech Discussion
    Last Post: 08-05-2012, 02:44 PM
  2. Key comes out of ignition in every position.
    By LastPatriot in forum General Grand Prix Discussion
    Last Post: 06-26-2012, 08:39 PM
  3. Ignition key, won't turn to off position
    By buck in forum General Tech Discussion
    Last Post: 01-11-2012, 12:29 PM
  4. Ignition will not turn to start position
    By glovey in forum General Tech Discussion
    Last Post: 08-08-2011, 03:51 PM
  5. Ignition stuck in OFF position
    By chilipepperpizza in forum General Tech Discussion
    Last Post: 06-29-2010, 07:25 PM
