I have a 2004 Comp G that recently developed a problem of not getting full boost. This is all based off the factory guage and it wont reach full blocks until about 5k. I tried unplugging the bottom vac line off the boost actuator and still nothing. I sprayed brake cleaner around trying to find a vacuum leak but the idle didnt raise at all. The boost actuator arm drops down the full length when the gas is floored as it should. Any ideas?
I do have coolant that is disappearing so i'm pretty sure i need lower intake gaskets. Perhaps under the manifold it is sucking in air which may be causing my issue? I am not sure at this point because on my last few cars when this happened i just unplugged the vac line from the bca then got a new one to solve it. Any ideas and help is appreciated, thanks!
