Thread: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
Results 1 to 20 of 28
  1. #1 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    May 2013
    Hortonville, WI
    I have an 04 gtp, I am wondering what i can do to it that is cheap and easy to get some more power and mileage out of it. I dont want to have issues down the road from doing anything to it though. I sthere some stuff out there??
  2. #2 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Lean burn tune. P&p heads. headers
  3. #3 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Cambridge, Ontario Canada
    P&P heads doesn't exactly fit with "easy" or "cheap" haha
    Try an intake
    Aftermarket PCM
    Downpipe & 3.6 pulley
    You will end up using more gas tho as the right foot gets heavier
    Anything after that is getting a little further out of the "easy" column for someone at the newb stage
    2005 E55 - stock
  4. #4 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    May 2008
    Schuyler, NE
    L26 bottom end, and a full size IC.
  5. #5 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Omaha, NE
    Nitrous
  6. #6 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    May 2013
    Hortonville, WI
    OMG some of you dont understand easy and cheap do ya. Ya i thought about intake, dont really wanna run a diff pulley cause then im pushin more air through and have a posibility of blowin intake gasket or somethin like that. Ne other ideas would be great.
  7. #7 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Most of us have different definitions of "cheap" and "easy". You might want to post a budget you have in mind and if you have any mechanical experience so we have a idea what you could install yourself etc.
    04 Comp G.
  8. #8 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    May 2013
    Hortonville, WI
    I am very mechanically enclined can do alot myself or with the help of dad who is a mechanic and the neighbor. and as cheap as possible, but still a good product. How about just a k/n filter would that help, i have had many k/n filters, and cold air intakes before just not sure if they do anything.
  9. #9 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    If you don't drive the car for the winter, P&P your own heads is a great mod. Pretty cheap, and still reliable.
    Intakes are a waste of time.
  10. #10 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Dec 2012
    Where 4T65E's were born
    They're worth it on GTP's. You get more supercharger whine, and with forced air induction, you may see a bit more HP. They're nearly a waste of time on N/A engines.
    Sold.
  11. #11 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    May 2013
    Hortonville, WI
    Ya i had an 03 gtp with a cold air system on it, and it sounded awesome, and seemed like it had a quite a bit more power. I do drive it in the winter, but not much i try to keep it out of the salt as much as possible. I have to take it in on monday i have been havin a prob with #3 missing alot! Not sure what it is have had many diff ideas thrown my way, but hopefully its not what some are thinkin a hole in the piston, or ne thing internal hopefully!! So after that i will have to see what i can do. Might be puttin in diff engine if piston is bad or lifter,1,400 just to take heads off for labor only!! Can get a engine new refurbished for 2,000.
  12. #12 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Or they could charge you .5 to stick an inspection camera in the spark plug holes.
  13. #13 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    K&N is not worth it. Make your own intake or Cai for cheap and should achieve the same results.
    04 Comp G.
  14. #14 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    May 2013
    Hortonville, WI
    ok well i'm thinkin im just gonna put a good filter in it for now and see what else i can do for cheap later on. dont really wannna do ne thing with the supercharger dont wanna mess with the big dollar big wrecking ball things i have bad luck so like i said wanna keep it cheap and still keep the power house reliable..
  15. #15 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Aug 2008
    SoCAL
    Nitrous
    Yep
  16. #16 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    May 2013
    Hortonville, WI
    this car is my daily driver for work. Just lookin to get alittle more playin power out of it not racing, and if possible a little better mileage.
  17. #17 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Omaha, NE
    Nitrous is exactly what you're looking for. It's not like you're spraying 24/7...
  18. #18 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Aug 2008
    SoCAL
    Nitrous is very safe if its done properly. All those that blew up their motors (back in the 60s and 70s) paved the way. You spray Nitrous and fuel together. I had a progressive kit on my supercharged Saleen Mustang. Now that was fun!!! You get great gas mileage all the time.
    Then when you want to race and have a little fun, flip a switch.
  19. #19 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    May 2008
    Schuyler, NE
    I had nitrous on my daily driver that I put 40k miles on a year. The car now has 163k miles on it, runs 11's, and is still on the original engine and transmission.
  20. #20 Re: 04 gtp looking to up the horse power and mileage, but keep reliable and cheap??
    Dec 2012
    To be serious, aren't the only mods that increase power AND fuel economy, flow mods? HAI, headers, down pipe, port/polish intake, etc.
    Of course there are things like new plugs, cleaning the maf, etc. that help as well but aren't mods.
    Sold.
  1. Replies: 12
    Last Post: 07-21-2013, 08:40 PM
  2. Where to find Reliable Cheap dbl din
    By Timing in forum Audio, Security & Visual Electronics
    Last Post: 02-03-2013, 07:33 PM
  3. Reduction in power, gas mileage drop
    By jokyfo in forum Engine
    Last Post: 01-06-2011, 01:51 AM
  4. Hello my name is Ryan I have an Horse Power addiction!
    By Boosted CC in forum Introductions/Noob Questions
    Last Post: 01-09-2010, 11:04 PM
