I just bought a pretty clean 97 GTP with a low miles engine and trans last sunday about 4 days ago. Me and the crew made our typical stainless straight through exhaust with our drone eliminating technology (Turbo Dynamics Canada)
The exhaust starts at the bottom of the down pipe, goes to 3" (catless) 2 resonators style muffler 2 bigger mufflers on each side near the bumper (divides 3 to 2.5 inch).
exhaust sounds beautiful and is extremely quiet, no drone at all even with no rear interior.
We also took out a lot of weight out of the car around 300lbs. The front of the car is still all there including the leather seats.
I installed a very large AEM air filter picking up where the old airbox used to be. I'm still running the stock 3.8 pulley...
I have a small race tank running a Walbro 255 HP external pump through the stock fuel lines.
Everything else is all stock. The tires are actually still 18" winter tires, far from ideal for performance.
I Plan to do a twin engine GTP with it, but first, I have to make it run pretty fast FWD. Then we will add the engine in the back.
I installed HP tuners downloaded the stock 97 tune from the ECU, didn`t touch it then datalogged our run.
1st of all the car's performance increases are massive compared to when it was 100% stock. I was shocked.
I expected around 10-15HP max from the exhaust and large air filter but it is easily double that if not more. My guess is that, the exhaust gave more 40-50HP is that even possible for a GTP ?
My ass dyno is usually pretty close as I do a lot of tuning.
The car is a monster now for how little mods are in it. Before it would spin a little and hook and go. Felt like a 14.7 car @ 94 mph or so my guess.
Now it spins all through 1st gear until the shift to 2nd... way quicker than before. Yes the weight reduction made a big difference equivalent to 27HP but the difference is way more than this.
I then started playing with the transmission tune and raised the rev limits and shift limits looked.
Wow pulls even better by staying in the powerband. Now with the exhaust the car feels like it wants to shift past 6K unlike when it was stock.
Now my HP tuners datalog on my stock MAF says I'm running a peak of 31 lbs/min at the 6000rpm. I'm touching 8 psi at Redline on the stock 3.8 pulley.
The car feels amazing, now I'm starting to understand why many don't recommend smaller pulleys.
This is on 91 octane btw and I was also shocked to see I had massive knock. Before the rev limit increase knock wasn't bad but I would get 3-4 deg often.
With the rev increase knock up to 9 deg , yikes... I then added Torco octane booster to my small race tank. And that helped a little but didn't get rid of the knock.
Then I put 50/50 C16 and 91 and BAM, the knock is GONE. Not once did I see even 1 deg. So it is Real knock at only 6-8 psi with the stock pulley with a very high flow exhaust.
Those steel heads are in large part responsible for this in my opinion. This is why intercooler helps so much, it keeps everything around the core cool, With an iron head the heat from the combustion stays trapped.
Anyhow I logged a 4.9 0-60mph by modulating throttle and 100mph in 12 seconds. Not bad for a start and on winter tires.
E.T. street 18 inch radials should be in next week, and that will drop the time by a long shot.
Tomorrow, methanol injection, 2.8 pulley from ZZperformance...
btw this isn't an ad. We have no plans to make exhaust for GTPs.
