Thread: Smelling gas..
Results 1 to 18 of 18
  1. #1 Smelling gas..
    Mar 2013
    Spring, TX
    Alright so I have a 99 GTP with 121,000 miles. I noticed after going WOT almost every time I will smell a little bit of gasoline shortly after.. I have the P0440 code and I'm not shure if the two could be related at all. I don't see any visible gas leaks anywhere either. Any ideas?
  2. #2 Re: Smelling gas..
    Pop the hood and pull the loom covering the fuel lines back/off. See anything now?
  3. #3 Re: Smelling gas..
    Gas cap.
    EVAP solinoid...or the carbon canister.
    Try checking those.
  4. #4 Re: Smelling gas..
    Gas cap and canister are behind the cabin, would be tough to smell them while moving.
  5. #5 Re: Smelling gas..
    Mar 2013
    Spring, TX
    Hmm this is true.. I was thinking it might be the gas cap because the metal part of it is looking a bit rusty and there is a bit of a gap between the plastic cap and the metal. I noticed after driving it for a while when I shut if off and walk by the back near the gas cap i'll smell gas sometimes too. Thats why I thought that might be it. and bill where is the loom covering the fuel lines? I'm new to these cars and new to doing stuff like this period.. hah
  6. #6 Re: Smelling gas..
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    fuel pump o ring...happen to 2 gtp so far i have fixed one was a 99 other was a 02 no leaks but smells gas on wot and sets that code take off the cover and jack the car up in the front see if u see it leak out any around the pump
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  7. #7 Re: Smelling gas..
    Mar 2013
    Spring, TX
    Quote Originally Posted by 00grandprixgtp View Post
    This makes sense to me.. I have no way to jack the car up though. A buddy of mine has a lift though and I should be over at his place next week.
  8. #8 Re: Smelling gas..
    The fuel pump is at the front of the car and you have to jack it up to change the o-rings on the injectors?
    Well, ****.
    This is news to me.
  9. #9 Re: Smelling gas..
    Mar 2013
    Spring, TX
    Do you think this is also why I have to let the fuel pump run 2-3 times to get my car started without cranking it a thousand times?
  10. #10 Re: Smelling gas..
    No, that's from lack of fuel pressure.
    Sounds like your pump is dying.
    Test it at the rail.
  11. #11 Re: Smelling gas..
    Mar 2013
    Spring, TX
    So could I just replace the whole pump and fix all of these issues?
  12. #12 Re: Smelling gas..
    Probably.
    It's a '99, test that by removing the fuel pump relay and bending the tab out of the way, like so...will fix hard starts and a dying pump and no start condition most of the time in the 97-00 GTP's.
  13. #13 Re: Smelling gas..
    Mar 2013
    Spring, TX
    alright thanks a ton for the help guys. I'll let you know if it continues.
  14. #14 Re: Smelling gas..
    Hold up a minute Ace.,. you've been given some incorrect information.
    I have no idea where this guy got his information or maybe he's dyslexic, but the pump is located under a hatch in the trunk. And you don't jack anything up to open the hatch. Unless his suggestion is to fill the tank and jack up the front of the car to look for leaks around the o-ring at the top of the tank. His post is about as clear as mud.
    Quote Originally Posted by blueguy View Post
    Probably.
    Now..this goober is a buddy.. however he doesn't quite remember that the pump primes the cylinders in high speed mode, not low speed. See your fuel pump runs at two different speeds based on what is going on. At key turn on to start up, it's high speed mode to provide full pressure and prime the engine to start. Once idling, it's in low speed mode which uses a resistor to give it less voltage to run slower. This resistor does go bad and the symptom is the car starts then dies in 2-5 seconds. The way to test/get around the low speed mode is to bend the tab on the relay. When you get into the throttle heavy or wide open, the pcm commands full speed on the pump.
  15. #15 Re: Smelling gas..
    Mar 2013
    Spring, TX
    Yeah I'm a noob so i'll believe anything i'm told haha. I now know where and how to replace the fuel pump. I think the pump is just dying though.. I've driven the car 500 miles in the past three days and it has just developed a rough idle and has been starting pretty rough the past while. Could these things be caused by the fuel pump failing? It's also gotten a bit whiny these past few days..
  16. #16 Re: Smelling gas..
    Dying pump would be low pressure or a bad supply when on the throttle. However.. a bad pump won't cause a gas smell unless it cracked or something, which I've never seen happen.
    I'd suggest checking fuel pressure if you think the pump is going bad. There are many things that can cause a hard start/bad idle. Most not the pump. Heck.. I'm beating a 217K mile pump in my Regal, it gets nice and low, then filled up all the time. Damn thing is kicking butt still. Yeah.. I haven't even changed the filter.
  17. #17 Re: Smelling gas..
    Mar 2013
    Spring, TX
    Alright haha. Well you have a point and i'm definitely not having any issues while on the throttle. I just need to figure out how i'm losing fuel pressure after letting it sit for a while and whats causing my hard start/rough idle. Could the hard start and idle be caused by plugs and/or wires?
  18. #18 Re: Smelling gas..
    There's a check valve in the pump. Often they go bad and that allows pressure to bleed down.
  1. Keep smelling gas in my car
    By sammie in forum General Tech Discussion
    Last Post: 04-14-2012, 12:34 PM
  2. Car smelling like gas any idea where its coming from?
    By DBGP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2011, 07:37 PM
  3. smelling fuel.
    By salty711 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-29-2011, 09:13 AM
  4. Smelling antifreeze
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 11:06 PM
