Thread: Thermostat housing sealant?
Results 1 to 20 of 28
  1. #1 Thermostat housing sealant?
    GT Level Member GTPRiley's Avatar
    Oct 2008
    Abilene Texas
    Hey guys I changed my thermostat to a 180 recently and since then I cant get my thermostat housing to seal up and its leaking slightly, what should I do to get it sealed up... Thanks guys!
    Riley Greear
    "Bastardized" 2004 Grand Prix GTP Comp G. 180* Tstat, Fender Well Intake, AL 104's SSAC Headers 3.5 MPS XP-HOT Cam and 105# springs.
  2. #2 Re: Thermostat housing sealant?
    GT Level Member beastin1's Avatar
    south elgin il.
    Quote Originally Posted by GTPRiley View Post
    did you replace the rubber gasket??? otherwise try silicone sealent....hi temp of course
    2002 Galaxy Silver 4dr. GTP...supercharger heaven.
    IM ON IT!!!!!!
  3. #3 Re: Thermostat housing sealant?
    if the rubber gasket is new(er) it should seal just fine.
  4. #4 Re: Thermostat housing sealant?
    Oct 2008
    Abilene Texas
    Thats the thing its a brand new gasket, and at first it wouldnt seal at all. I flipped it and it sealed better, can I get a high temp silicone sealant from Lowes?
    Riley Greear
  5. #5 Re: Thermostat housing sealant?
    Barksdale AFB, LA
    Yeah, the gasket is only one way. If you even got it in backwards it may be damaged and that's why it isn't sealing. It's somewhat "bowl" shaped so it will fit down into the LIM and the housing will seal on top of it. This provides the seal so coolant won't get out, and also so that coolant can't get around a closed thermostat.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Thermostat housing sealant?
    Moore, Oklahoma
    From my experiance with a couple Series 2 3800 and doing coolant flushes yearly i learned something. Over time it seems the rubber seal on the Thermostat which is designed to seal the housing too eventully won't seal good. My solution? Simple, use a LIGHT coat of gray permetex RTV (water pump/t-stat housing) around the housing and it will cure it. And thats with using a new rubber seal too. I always replace the seal everytime too. Don't put RTV on the T-stat seal, just the housing only.
    Good luck...
    Shawn W. Larsen
  7. #7 Re: Thermostat housing sealant?
    Oct 2008
    Abilene Texas
    Alrighty, Ill just get some High heat silicone stuff tomorrow from Lowes or something that should seal it up. I hate the smell of Antifreeze burning, its horrible lol.
    Riley Greear
  8. #8 Re: Thermostat housing sealant?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Do not go to Lowes for automotive parts. You need to go to the autoparts store and pick up the red RTV. It is designed for seals like that. Use it sparingly and you should be good.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  9. #9 Re: Thermostat housing sealant?
    Oct 2008
    Abilene Texas
    Ok I got it, it should work just fine...
    Riley Greear
  10. #10 Re: Thermostat housing sealant?
    south elgin il.
    yea, that RTV is the exact stuff ya need, i just couldn't remember the name yesterday when i posted.... but i've got a tube in the garage right now, too bad you don't live closer....lol
    IM ON IT!!!!!!
  11. #11 Re: Thermostat housing sealant?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Quote Originally Posted by Iron Indian View Post
    Good luck...
    That's what I used too, works great.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  12. #12 Re: Thermostat housing sealant?
    Oct 2008
    Abilene Texas
    Ok I didnt get the Gray but I got the red stuff and its High Temp... Hopefully it will seal up Im sick of it leaking, makes the driveway look horrible and it smells even worse...
    Riley Greear
  13. #13 Re: Thermostat housing sealant?
    south elgin il.
    i got the red too...should be just what the doctor ordered, although consider picking up a new gasket first, that way all bases are covered
    IM ON IT!!!!!!
  14. #14 Re: Thermostat housing sealant?
    Jul 2008
    Dekalb, IL
    Nah Straight RTV is fine.
  15. #15 Re: Thermostat housing sealant?
    Oct 2008
    Abilene Texas
    I got the gasket at the same time as I got the RTV so it should work out lol, I swear if this doesnt stop leaking lol
    Riley Greear
  16. #16 Re: Thermostat housing sealant?
    Oct 2008
    Abilene Texas
    ITS FIXED!!! No more leak, No more smell. No more Smoke... RTV is the ****! Thanks everyone for helping me out.... WHOO!!!
    Riley Greear
  17. #17 Re: Thermostat housing sealant?
    Barksdale AFB, LA
    I can't believe you guys have trouble getting it to seal. I bet your gasket surfaces are dirty. I wipe it down and scrape the housing side every time I change one out. Did my fourth change today, and still no issues sealing.
  18. #18 Re: Thermostat housing sealant?
    Oct 2008
    Abilene Texas
    Sabre what all is done to that Impala eh eh??? C'mon tell me lol.
    Riley Greear
  19. #19 Re: Thermostat housing sealant?
    south elgin il.
    congrats on the fix Riley
    IM ON IT!!!!!!
  20. #20 Re: Thermostat housing sealant?
    Barksdale AFB, LA
    North American Impala Owners Association - Garage - Sabrewings's 2004 Chevrolet Impala
  1. Removing alternator housing
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2010, 06:14 PM
  2. M90 PCV cover sealant?
    By Sabrewings in forum General Tech Discussion
    Last Post: 10-16-2008, 02:54 PM
  3. headlight lens and housing
    By TDCRacing in forum Shops and Community Heroes
    Last Post: 08-30-2008, 01:14 PM
  4. Is painting the SC housing bad?
    Last Post: 02-15-2008, 12:30 AM
