Thread: Rear Knock Sensor - should it be plugged in?
Results 1 to 9 of 9
  1. #1 Rear Knock Sensor - should it be plugged in?
    Cambridge, Ontario Canada
    Code the nasty P0332 code bank 2 knock sensor low voltage. Had a look at the pig and noticed the wires connected to the KS connect to nothing. Is that correct?
    N-ass-tee spot
    Zip tied to a tranny line, plugs into a plastic piece of nothing. Really hoping this is the problem
    2005 E55 - stock
  2. #2 Re: Rear Knock Sensor - should it be plugged in?
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    It has to be plugged in. Look for the wire it is probably hanging somewhere it is only one wire that goes to it. I literally plugged mine in today.
    If You Cant Hear The Whine You're Too Far Behind...
  3. #3 Re: Rear Knock Sensor - should it be plugged in?
    rear knock sensor wire is clipped to the bottom back of the p/s pump, look for it in that area.
  4. #4 Re: Rear Knock Sensor - should it be plugged in?
    There will be a single wire (without end from your pic..lol) in the harness that connects to the vss (trans speed sensor) and oil pressure switch. Holler if you need a picture of it, I have a harness or two on the wall I can get one from.
  5. #5 Re: Rear Knock Sensor - should it be plugged in?
    Holla - pics always help
    2005 E55 - stock
  6. #6 Re: Rear Knock Sensor - should it be plugged in?
    I am hoping this BS is causing the P0332 code - low input voltage for bank 2
    Still doesn't explain my horrendous KR but might explain why timing is still pretty strong with 5-8 degrees of knock (assuming its real) - car still pulls like a cheetah for a stock pulley low tech 3.8
    2005 E55 - stock
  7. #7 Re: Rear Knock Sensor - should it be plugged in?
    Well..depending on what the wire it touching..it might.
    Get your butt out there.. and look for the wire. I'm not posting a pic..until you try!
  8. #8 Re: Rear Knock Sensor - should it be plugged in?
    Suit & tie right now, thinking about diving under there desipte that! lol tonight just before the Leafs game.
    Just to be clear, it goes SENSOR > SINGLE WIRE > PLUG > DIFFERENT PLUG > SINGLE WIRE > HARNESS THAT INTEGRATES WITH VSS & OPS?
    That "DIFFERENT PLUG" should be just behind the PS pump?
    2005 E55 - stock
  9. #9 Re: Rear Knock Sensor - should it be plugged in?
    To be clear...it really goes
    Sensor in a location that's a pain to a pigtail extension.
    Extension typically to a connector at the back of the ps pump where it connects to a single wire
    That single wire is in teh loom that comes down from the top of the motor. In it is the wiring for the oil pressure, rear knock (single wire), VSS and rear O2
  1. Loads of KR with headers, rockers & stock pulley - 11 PSI too...
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2013, 09:15 PM
  2. Rear knock sensor / power steering pump / rack & pinion question
    By miwalter928 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 09:38 AM
  3. Rear Knock Sensor
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-16-2010, 04:05 PM
  4. Help! Rear knock sensor
    By cav in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2010, 12:26 PM
  5. Rear Knock sensor P0332
    By cav in forum Introductions/Noob Questions
    Last Post: 03-26-2010, 07:51 AM
