Thread: Advice
Results 1 to 3 of 3
  1. #1 Advice
    Nov 2008
    NY
    does anyone know what i should charge on a 99 used Stock Downpipe? from a GTP
  2. #2 Re: Advice
    PA
    Does it still have the stock cat on the end of it? If so, $75 because the cat is worth a lot.
    If it is just the pipe from the exhaust manifold to before the cat, then $20.
    2001 GSE
  3. #3 Re: Advice
    Oklahoma
    Moved to the correct section.
    Familiarize yourself with this:
    http://www.grandprixforums.net/f14/a...read-6828.html
    Post #7
  1. Need Paint Advice
    By JJ91284 in forum Visual/Body Modifications
    Last Post: 09-30-2008, 08:43 PM
  2. Can I get some advice..
    By biggmman in forum Turbo
    Last Post: 09-29-2008, 10:43 PM
  3. Need some advice here
    By biggmman in forum General Tech Discussion
    Last Post: 09-27-2008, 05:03 PM
  4. Need some advice here
    Last Post: 09-27-2008, 03:28 PM
  5. Need Advice on 97 GTP
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 03-02-2008, 12:46 AM
