Thread: Car all of a sudden will not start
Results 1 to 20 of 31
  1. #1 Car all of a sudden will not start
    Florida
    Was going to head out a few min ago but to my surprise car wouldnt start. I try 3 more times and still nothing. Now heres the thing If i turn it to the first notch it displays on my DIC my mileage but when i switch it to acc. nothing comes on until i gave it a few min then music came on but still no start. Then I kept trying to turn it over and start then the music and warning chimes wouldnt come back on, it would click like it wanted to come on but nothing. And I also hear some clicks and my dial needles shimmy up and down. The check engine light also repeatedly flashes as i try and start it. What could this be? And my key fob wont lock or unlock it as well.
  2. #2 Re: Car all of a sudden will not start
    Jun 2012
    Ontario Canada
    Check gas cap is tight, had that problem the other day
  3. #3 Re: Car all of a sudden will not start
    Florida
    Yea its definately not that. Already checked that just in case. I had my neighbor give me a jump and it still wouldnt start, so im thinking starter/alternator.
  4. #4 Re: Car all of a sudden will not start
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    alternator has nothing to do with starting the car.
    do you have a volt meter? test your battery voltage. likely toast battery.
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  5. #5 Re: Car all of a sudden will not start
    Florida
    No volt meter. But things come on thats what I dont get, soon as I open the door interior lights are on and mi DIC display is on. I turn the key and radio/clock display pops up but then wont start. Turn everything back off and try again repeatedly and things wont come on anymore unless i keep trying or give it time. And when i turn it all the way to starting position i get this hum noise under the hood.
  6. #6 Re: Car all of a sudden will not start
    bad grounds, or the ignition harness may have taken a vacation leave.
    check the 3 main grounds on the trans bell housing, make sure they are still bolted on and clean and tight.
  7. #7 Re: Car all of a sudden will not start
    Ohio
    Yeahh... Your battery is dead Darrell lol
  8. #8 Re: Car all of a sudden will not start
    Mar 2012
    Dallas
    had a gas powered forklift, do the same thing, even while jumping off with another lift, it would barely turn over and some attempts not turn over, just click. had to swap out batteries to get it to start.
    like scotty said, make sure your grounds are nice and clean with no corrosion.
  9. #9 Re: Car all of a sudden will not start
    Check your battery terminals.
  10. #10 Re: Car all of a sudden will not start
    Florida
    Well seems like its pointing to the battery which i hope. But cant do nothing til tomorrow anyway, too dark.
  11. #11 Re: Car all of a sudden will not start
    Sep 2011
    MI
    turn your headlights on. Are they bright or dim? If they are bright then your battery is probably OK, and you could have an ignition switch issue. Usualy if the battery is so dead it won't even click when you try to start it, it wouldn't have enough power to turn on the radio or the dome lights.
  12. #12 Re: Car all of a sudden will not start
    Florida
    Well The lights would come on when it gets that sudden chance like it wants to come on but then wont come on again after awhile. I tried to flash the high beams and nothing. Ill just replace the battery and if that dont work then ill just take it back and have car towed to my mechanic.
  13. #13 Re: Car all of a sudden will not start
    Try cleaning your battery terminals before you replace it
  14. #14 Re: Car all of a sudden will not start
    Florida
    Yea gonna try this stuff in a few once more sun lights stuff up. Really hope this Is simple. Another thing don't know if it makes a difference but when I close the hood I hear this static shock noise sometimes.
  15. #15 Re: Car all of a sudden will not start
    Sun is up... C'mon.. get going
  16. #16 Re: Car all of a sudden will not start
    Florida
    Well battery terminals are spotless,I even undid the negative cable for 15min and made sure it was back on tight. And still nada. There's that noise though its a hum click type of sound coming from battery area so it May just be the culprit. It puzzles me how this came all of a sudden though,no warnings and cars been starting fine.
  17. #17 Re: Car all of a sudden will not start
    Well...things do happen.
  18. #18 Re: Car all of a sudden will not start
    Florida
    Well replaced the battery and car did start up twice. But not jumping for joy just yet,gonna take it up to my mechanic and have them test the old battery and my alternator and starter just to be sure.
  19. #19 Re: Car all of a sudden will not start
    Can I be your mechanic? Free money is great.
    Alt.. test battery with tons of stuff running to see if power is there or dropping. Multimeter
    Starter...turn key a few times
    Old battery...any AZ or Advance will test free
  20. #20 Re: Car all of a sudden will not start
    Florida
    My alternator is the culprit! Took it to mechanic and voltage was a lil high but good. Had me turn everything on and voltage dropped to red then went back up some. He said that points to.my alternator which makes sense but damn I'm a lil pissed now.
  1. blowing my HID fuse all of a sudden...WTF?
    By fst in forum Audio, Security & Visual Electronics
    Last Post: 12-27-2011, 09:48 AM
  2. Sudden MPG increase
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-01-2011, 12:58 AM
  3. Sudden Drop in MPG
    By Steel Armadillo in forum Engine
    Last Post: 11-06-2011, 11:42 PM
  4. so all of a sudden im motivated....
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2008, 10:44 PM
  5. Sudden tranny problems...
    By Blinksy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2008, 12:16 AM
