I was told there's a screw somewhere near the s/c that you could raise or lower the amoust of boost produced. I know its not gnna change it 4-5 psi but I would guess 1-2 if anyone knows the locatioon or if it even exists that would be great
What it actually does it help you get into boost faster or slower. Based on valve rod travel. If you look at the front side of the SC. There's two 10mm screws. Those are the ones you want.
Cam, Wouldn't the flow mods negate smaller pulley. Sure it would give you more power, you could retain the same boost levels though.
oh, so which way CCW OR CW?
You loosen them (ccw), push the BBV down all way, then tighten them back up (CW).
