Thread: Help! exterior/body people
Results 1 to 10 of 10
  1. #1 Help! exterior/body people
    GT Level Member titanfan12's Avatar
    Jan 2013
    west palm
    whats the best way to go about changeing a fender?
  2. #2 Re: Help! exterior/body people
    Banned
    Sioux Falls, SD
    Take the hood off, bumper off, and lower rocker moulding. And depending on the side the washer fluid resivor also has to come off.
  3. #3 Re: Help! exterior/body people
    Jan 2013
    west palm
    its the left and how long do you think this would take
  4. #4 Re: Help! exterior/body people
    Jan 2013
    west palm
    *right my bad
  5. #5 Re: Help! exterior/body people
    Banned
    Sioux Falls, SD
    Idk depends i do it on a daily basis
  6. #6 Re: Help! exterior/body people
    Johnstown, NY
    Remove the front bumper by removing the push pins near the hood latch and 1 bolt (think it's either a 10mm or 8mm) on each side, then pull the bumper forward to get it off. then to remove the fender there's a number of bolts around the area.. Where the fender and door meet, where the fender and hood meet, along the splash guards, and at the bottom of the fender near the jack point. Once those are removed the fender should just fall off and you can re-install and bolt on.
    Should take about 1-2 hours, depending on condition of bolts.
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  7. #7 Re: Help! exterior/body people
    Banned
    Sioux Falls, SD
    Quote Originally Posted by Jevik View Post
    Hood needs to be removed because the hinges are welded to the fenders
  8. #8 Re: Help! exterior/body people
    Johnstown, NY
    Quote Originally Posted by MidnightBlue View Post
    Ah yes. Forgot about that.
  9. #9 Re: Help! exterior/body people
    SE Level Member GEMINIokc's Avatar
    Dec 2008
    n side
    Sorry to piggyback on someone else's post but this seemed the most relevant for my situation. What if all you need to do is reposition the fender? whenever you open my passenger side door it pops because the door is slightly pinching or hitting the fender. not enough to do any damage to it, but annoying nonetheless. Just curious because the above statement said that the hinges for the hood were welded to the fender panel. so i just want to make sure that i am not going to screw up the alingment of my hood by moving the fender forward a minute bit. Any help is much appreciated
    UPDATED MODS....GreenBastard HP powertune, CAI, BlueGTP91 Engine bay detail, Finished painted Dash,Hogans Performance DP, Flow Master 40's, Still Missing driver side badge 4 weight reduction.... More Mods Coming Soon!!
  10. #10 Re: Help! exterior/body people
    my door was hitting too, just last week, thought it was a dry hinge, but it kept on after lubing, so i watched the door hit the fender down low, with a open door and two bare hands i pulled the fender out a bit and the door clears now.
    in your case, first id test the door hinges.
    open the door all the way, then see if you can lift the door from the open end, if it moves up, thats your door hinges failing.
  1. Need some exterior ideas..
    By dmahlikGT in forum Visual/Body Modifications
    Last Post: 02-04-2013, 07:42 PM
  2. Metal Strip on Body Beneath Door Exterior?
    By Grand in forum Visual/Body Modifications
    Last Post: 09-14-2012, 10:05 PM
  3. Visuals and exterior
    By 2004GrandPrixGT1 in forum Visual/Body Modifications
    Last Post: 07-15-2012, 09:02 PM
  4. gxp exterior (extras)
    By 06GPGXP33 in forum Visual/Body Modifications
    Last Post: 12-15-2011, 07:00 PM
  5. exterior
    By CHAMPS97 in forum Visual/Body Modifications
    Last Post: 06-16-2009, 11:18 PM
