Thread: Braided Fuel line for only $15
Results 1 to 3 of 3
  1. #1 Braided Fuel line for only $15
    Florida
    Ok I had a set years ago and never used them... then lost them when i moved. So i got another set. the 95 Lumina APV mini van with a 3800 comes factory with braided fuel line. not sure why they went with them but hey! good for me. they seem to be the same length as my l36 lines and will do nicely when i install the top swap as i can use the same fittings i used to install the l36 lines when swapping from the DOHC. just figured everyone could use the info.
  2. #2 Re: Braided Fuel line for only $15
    Toss us a bit more info about the way you connected etc. That would be a score ....if there were any Lumina dustbusters in the yards.
  3. #3 Re: Braided Fuel line for only $15
    Florida
    Ok I used compression fittings like these for when I swapped to the L36 lines from the LQ1 (DOHC). I left the metal line intact on the lines on the L36 set and also for this braided set. I cut the lines on the car back to the hard metal as well.:
    Braided Fuel line for only Attached Images
  1. How to Braided fuel lines
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 09-11-2012, 03:20 PM
  2. Stainless Steel Braided Lines
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 08-28-2012, 04:13 PM
  3. Braided Brake Lines - What are our options?
    By Zef_66 in forum Brakes/Suspension/Chassis
    Last Post: 08-18-2011, 08:06 AM
  4. steel braided brake lines
    Last Post: 10-24-2008, 10:15 PM
