Thread: Help me build my engine
Results 1 to 16 of 16
  1. #1 Help me build my engine
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    As some of you know I chipped a piston...
    So now that this happened I am going to gut the block and hone the walls and rebuild!
    I plan to reuse the crank, I plan to add
    -Diamond Forged Pistons w/ L32 rods 14k on them (replacing rings) 8:9:1
    -Clevite 77® TriMetal™ Main and Rod Bearings
    -LS7 Lifters
    -Intense S2X
    -105# Valve Springs
    -Stock Rockers
    -Stock Valves
    -Stock Push Rods
    I am just looking for any advice or suggestions for parts...
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Help me build my engine
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Use platigage to check your clearance on the main and rod bearings to make sure you use the right ones especially If you're going to spend the money on clevite. Take your time and don't rush. Check, check, and recheck. Torque everything to specifications. You should be fine.
  3. #3 Re: Help me build my engine
    May 2008
    Schuyler, NE
    I would stick with L67 rods.
  4. #4 Re: Help me build my engine
    Cambridge, Ontario Canada
    turbo cam right...?
    2005 E55 - stock
  5. #5 Re: Help me build my engine
    I believe he presently has L26 rods.
  6. #6 Re: Help me build my engine
    May 2008
    Schuyler, NE
    I would definitely get rid of those.
  7. #7 Re: Help me build my engine
    Forsure.
    Toothpick rods FTL.
    I'd suggest a stock L36, get a better performing cam than an S2X and enjoy.
  8. #8 Re: Help me build my engine
    Feb 2013
    37.295091, -121.930053
    Quote Originally Posted by jlgp2007nc View Post
    And if you think your check 5 more times lol. Also make sure the crank is dead straight. It will provide you with smooth and easy cranking once you put in all the pistons. If your first piston feels very stiff the n you have it at an angle and it will lock up on ya. Also too if your not sure about it let a machine shop that has built a few rebuild yours. Dont forget to use assembly lube on the bearings before you put in the crank or rods.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: Help me build my engine
    Apr 2012
    Middletown DE
    The new pistons are .030 over so I will send my block off the the shop for a hone. I might have them balance it too..
    I am the 4th owner of them but only the second car they have been in. the first car had the almost identical set up as me and the JP timing chain snapped and valves met piston.
    Two pistons have small dents in them but nothing to get me too worried.
    1993 Oldmobile 88
  10. #10 Re: Help me build my engine
    Feb 2013
    Quote Originally Posted by acidcrashdburnd View Post
    Umm any dent in a piston is bad. your valve train was off. In the picture you showed notice that there is no dents other than a chunk missing. That is how all 6 pistons should be. The piston that has the dent check the valves make sure they are not bent.
  11. #11 Re: Help me build my engine
    Re-read.
    The PO of the pistons had that PTV issue.
    Acid is saying the dents don't scare him.
  12. #12 Re: Help me build my engine
    Sep 2012
    North Carolina
    Yeah but the compression in those cylinders will be off just so and depending on where your build goes it may or may not cause problems. You want everything to be exactly the same. If you aren't blueprinting then whatever. It's just personally it would bother me.
  13. #13 Re: Help me build my engine
    Uneven flow distribution from the manifold, difference in flow in header primaries, difference in flow between injectors.
    Also note the M90 pulses air into the LIM, look at the MAP in your logs, it jumps to say the least.
    They're all going to be there one way or another. I can't see how a fraction of a CC of combustion chamber volume would affect anything.
    If the internet is to believed, the dents will create hot spots, for more KR goodness.
  14. #14 Re: Help me build my engine
    Apr 2012
    Middletown DE
    I have taken them to 3 machines shops and each one has said don't touch the piston it will be fine. If I were to smooth down the dented area it will cause more issues with weight balance is the answer I got from all three.
    I guess only running it will tell, hot spots or not I am using them.
    1993 Oldmobile 88
  15. #15 Re: Help me build my engine
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Any reason for JE over Diamond?
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  16. #16 Re: Help me build my engine
    Apr 2012
    Middletown DE
    Quote Originally Posted by ls1camino View Post
    Well I have Diamond because I get a set with L32 rods for $350 including a set of stock L67 pistons and rods
    1993 Oldmobile 88
  1. Engine Build
    By 06PONTGP in forum General Tech Discussion
    Last Post: 04-10-2012, 10:15 PM
  2. engine build...
    By gtpsleeper in forum General Grand Prix Discussion
    Last Post: 02-11-2012, 10:14 PM
  3. Engine Re-Build w/Z7 Kit
    By ARFF22 in forum Turbo
    Last Post: 02-13-2011, 06:22 PM
  4. Need advice on engine build.
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 06:40 PM
  5. Engine Build
    By ChrisGTT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2008, 04:18 AM
