I'm a little lost here.
Since when did SIII heads flow better?
They have the same crappy castings. Slightly larger valves, but they don't do much.
Also since when was the SIII timing cover worse?
It has much larger openings with smoother transitions.
If you're referring to the bumps in the walls, they really don't make that much of a difference.
