Thread: Replacement engine oil pump
Results 1 to 14 of 14
  1. #1 Replacement engine oil pump
    Feb 2013
    Missouri
    Hey everyone, so I owned my GTP for a total of 3 weeks before it spun a bearing. I'm replacing it with a JY engine, either 120,000 miles or 150,000 miles, still undecided on it. Before I drop it in, I'll be replacing the rear main seal\block gasket, LIM gaskets, valve cover gaskets, timing chain, timing chain tensioner, timing cover gaskets (duh), water pump, oil pan gasket, and the super charger coupler\oil. My question revolves around the oil pump. The only thing I can find at oreillys is a repair kit, which appears to come with a spring and a few gears. Should I bother with the oil pump? If I should "repair" is, what all is involved? Is there anything else I should do to this engine before I drop it in? I'll be pulling lifters\push rods\rockers to clean them all up as well.
  2. #2 Re: Replacement engine oil pump
    The few gears is the oil pump. It's a gyro type that is driven by the crank. Which is why these motors don't typically have an oil pump failure.
  3. #3 Re: Replacement engine oil pump
    Feb 2013
    Missouri
    So do you think I should just leave it alone?
  4. #4 Re: Replacement engine oil pump
    May 2008
    Schuyler, NE
    I would leave it alone.
  5. #5 Re: Replacement engine oil pump
    it is worth changing the spring and shaft to the upgrade version.
  6. #6 Re: Replacement engine oil pump
    The spring/piece are the pressure relief. By changing them you bring pressure up a bit.
    If you really want a good read. Find a post on 3800Pro about oiling deficiencies. It was by James..but that's not his SN on the forum. He cut blocks and heads etc into pieces to see where issues exist.
  7. #7 Re: Replacement engine oil pump
    Feb 2013
    Missouri
    This a really good read, but I'm not going to be tearing this block down that far. It did get me reading on the balance shaft delete, I'm not sure if it's worth it or not, this will be a relatively stock engine. What do you think Bill?
  8. #8 Re: Replacement engine oil pump
    Don't delete unless you have the engine down to a bare block.
  9. #9 Re: Replacement engine oil pump
    Feb 2013
    Missouri
    Done and Done then, cam and bottom end are staying in the replacement block. Depending on where I get the block, if I keep my old one I might tear it down and have some fun with it...
  10. #10 Re: Replacement engine oil pump
    Feb 2013
    Missouri
    What about just removing the gear that makes the balancer shaft rotate? I'll be replacing the timing chain, so it's literally right there.
  11. #11 Re: Replacement engine oil pump
    The only time I suggest that is when you want to use a double roller.
  12. #12 Re: Replacement engine oil pump
    Feb 2013
    Missouri
    Okay then, thanks for clearing it up, it'll stay stock.
  13. #13 Re: Replacement engine oil pump
    Look at it this way, the balancer is there to balance things out. Only take it out of the equation if you like vibration, want space for the double roller or have had the lower end balanced.
  14. #14 Re: Replacement engine oil pump
    Feb 2013
    Missouri
    Time to start another thread, I have another idea...
  1. water pump replacement
    By vandezand in forum General Tech Discussion
    Last Post: 01-01-2013, 12:18 AM
  2. 04 GT2 Water pump replacement
    By apok in forum Engine
    Last Post: 07-24-2012, 06:27 AM
  3. Water pump replacement
    By Ophidia in forum General Tech Discussion
    Last Post: 04-10-2012, 08:05 AM
  4. Fuel Pump Replacement?
    By swoollis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 06:14 AM
  5. Water Pump replacement
    By Reddcurrlz in forum General Tech Discussion
    Last Post: 02-25-2011, 04:07 PM
