Thread: North Star Throttle Body
Results 1 to 11 of 11
  1. #1 North Star Throttle Body
    Mercer, Pa
    The IAC valve fell apart, the solenoid part came loose from the little flange. The coil was hanging by the wires and the cork and stem were hanging out of the hole. The body of the valve was pressed into the flange originally. What year and engine are the zzp N* throttle bodies from?
    The cork part is bigger than the ones from L67 throttle body. I'm seeing prices over $100 for 2004 Cadillac N* with a 4.6 motor. I looked up a Bonneville with N*.
  2. #2 Re: North Star Throttle Body
    Should be a 2000+ Deville.
    Although IIRC any IAC even from an L67 is compatible.
  3. #3 Re: North Star Throttle Body
    Mercer, Pa
    Different shape and little smaller
  4. #4 Re: North Star Throttle Body
    Jan 2014
    United States
    My 1996 Deville has a 4.6 northstar, are you sure it needs to be a TB from a 2000+ Northstar?
  5. #5 Re: North Star Throttle Body
    Mercer, Pa
    I believe the bolt pattern is different. Need a different adapter.
  6. #6 Re: North Star Throttle Body
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    Throttle body is from any 00-05 front wheel drive Northstars including the Deville, Seville, Bonne GXP. The IAC is the same from 96-05.
    Email all inquiries to willoverkill@gmail.com!
  7. #7 Re: North Star Throttle Body
    If all else fails shoot me a message there's plenty of north* in the JY here I'm sure I can get one cheaper then $100.
    04 Comp G.
  8. #8 Re: North Star Throttle Body
    Jan 2014
    United States
    Haha you better. Im right outside st louis so Ill be able to find one for sure
  9. #9 Re: North Star Throttle Body
    Buffalo
    I've also heard the iac is the same aka same part different style but will work
  10. #10 Re: North Star Throttle Body
    Jan 2014
    United States
    Does the IAC mean Intake Air conditions? Like its the MAF sensor assembly?
  11. #11 Re: North Star Throttle Body
    Buffalo
    Idle air control. It meters the air from one side of the throttle plate to the other
  1. How and what is needed to add a North star to a gen 3 l67
    By thunder71173 in forum General Tech Discussion
    Last Post: 05-21-2011, 02:35 PM
  2. ported north star casing
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 03-08-2011, 10:46 AM
  3. North Star parts
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2011, 01:07 AM
  4. North * Throttle Body?
    By GenVGSX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2010, 02:02 PM
