with 1.95 rockers and stock springs you be floating not flying unless u keep rpms below 5000
Yea I might be fine... but I rather play it safe.
I think I read somewhere that stock springs are good for up to ~ .470" lift (could be wrong though)
Sure these engine components are over-engineered most of the time... but I'd rather not push my luck.
Lift wise stock springs will never bind on stock retainers.
Floating will never cause damage just leaves the potential for horsepower loss at high rpms... and reving extra on those rockers wont even gai. You anything either way.
Valve float can't cause damage over time?
lolk
Depending on how the valve floats, you can cause serious damage immediately.
said nobody ever (with a 3800)
You need to float the valve a solid 30 degrees or more at full lift to cause piston impact. These are not hemi heads nor are they anywhere near hitting the piston. You will lose enough power that by the time you are floating bad enough to get 10% of the way to the piston, the motor will just not run.
there shall be no valve float on my engine!
What happened to your motor then? ^^
seperated lim from charger and warped them both just enough to where no amount of gaskets or sealers will fix the giant vacuum leak
said engine also has 258k and has had the holy shi*t beat out of it but made me lots of money found a 110k replacement for 350
Lol @ combustion happening in the intake manifold. Now THAT insures complete combustion of the air and fuel. Shouldn't you make more power then? :Cartroll:
I missed you Ed, where you been? LOL.
I've just been lurking. I don't really post much in forums during winter. It's good to know that I was missed, I felt the same way about the forum. <3
