Thread: 3800 SC Valve Cover Bolts?
Results 1 to 8 of 8
  1. #1 3800 SC Valve Cover Bolts?
    Mar 2013
    Lake Wylie, SC
    Hello, just changed my LIM and putting everything back together when...UH OH...dropped one of the Valve Cover Bolts into the chassis (not the exposed engine thankfully!!)
    Does anyone know where I can buy a replacement one?
    BONUS: I also overtorqued one of the bolts connecting the SC to the lower manifold and the head broke off, leaving the bolt inside- I know I will have to drill it out unless someone has any suggestions (screw has broken off BELOW the hole) but does anyone have a source for these?
    Thanks for all of your help guys!
  2. #2 Re: 3800 SC Valve Cover Bolts?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    IIRC the sc to lim bolt is a 10x1.5...not sure about the VC bolt
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: 3800 SC Valve Cover Bolts?
    8 by 1.25 on teh LIM and the VC might be standard.
    Any local junkyard likely has both boths on a car if you have any self pull places.
  4. #4 Re: 3800 SC Valve Cover Bolts?
    Feb 2013
    Missouri
    I'd try an easy-out on the SC to LIM bolt, I've had them work about 50% of the time. Start soaking the bolt in PB blaster now.
  5. #5 Re: 3800 SC Valve Cover Bolts?
    Nov 2011
    NY
    Valve cover bolt is 1/4x20 - 1"
  6. #6 Re: 3800 SC Valve Cover Bolts?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    the sc to Lim bolt should be easy enough to get out with a bit of heat and a good set of vise grips, my guess would be that you would have an inch or so of material to torque on.
  7. #7 Re: 3800 SC Valve Cover Bolts?
    Hate me for posting this, BillBoost would do it like this...
    Often w/o pressure on it, you can use a small screwdriver or punch to back a bolt out. If that failed, I'd pull another lim off the shelf and be done. As for the bolts, well there's piles of them in the parts cases.
  8. #8 Re: 3800 SC Valve Cover Bolts?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    x2^^ also if you resort to drilling try a left handed drillbit, they can walk a bolt out before you have to e-z out
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. valve cover bolts
    By kawasakidrivinghick in forum Wanted To Buy - Parts
    Last Post: 02-19-2013, 07:46 AM
  2. Valve Cover
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 10:24 AM
  3. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
