Thread: lean condition...
Results 1 to 20 of 20
  1. #1 lean condition...
    Mar 2013
    maryland
    Hey guys my 98boost gtp is acting up. Im getting p0171 lean bank 1. My power is way down and my mpg is about 14.5. I have replaced plugs, wires, coils, maf, fuel filter, vac lines, head gaskets and all gaskets leading to heads. Fuel pressure test reveals 48 but the needle fluctuates very rapidly between 46-50. O2 sensors seem to be working. However my map is 9.7 steady at idle according to the scanner. I have checked fuel lines and cannot find any leaks. Also replaced injector orings. Pulled vac hose off pressure regulator and it was completly dry. Kinda at a loss. Thinking pump or clogged injectors. Although a map of 9.7in/hg seems low at idle. Any help would be greatly appreciated, thanks
  2. #2 Re: lean condition...
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    clogged Fuel filter? I'd change that before anything.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: lean condition...
    Mar 2013
    maryland
    Yes already swapped the fuel filter
  4. #4 Re: lean condition...
    9.7 is low.
    Have you read the fuel trims?
    What do they say at idle after it's gone into closed loop?
    Still sounds like a vac leak to me.
  5. #5 Re: lean condition...
    EGR tube may be cracked and causing the vac leak.
  6. #6 Re: lean condition...
    Mar 2013
    maryland
    Stft is about 614 at idle ltft is around 14 at idle. Egr tube i have not checked. I checked the egr valve which was good. What is the best way to check the tube? Remove it? If 9.7 map is low then there has to be a vac leak somewhere? Should i smoke test?
  7. #7 Re: lean condition...
    Mar 2013
    maryland
    Also i am getting the lean code for bank 11 not bank 2. Dont know if that helps. Thanks again for your responses
  8. #8 Re: lean condition...
    It's a vac leak.
    Spray carb cleaner around it.
    When the idle jumps, you found the leak.
  9. #9 Re: lean condition...
    Mar 2013
    maryland
    Ive drenched lim sc gaskets and all lines which are new. Should i spray the egr tube?
  10. #10 Re: lean condition...
    spray it or take it off and inspect it, its possible its cracked.
  11. #11 Re: lean condition...
    Hook a piece of vacuum hose to the map. Pull your scanner screen up and watch map as you suck and blow on the tube. It should move. If not..your map or the wiring to it is bad.
  12. #12 Re: lean condition...
    Pennsylvania
    Common issue for lean code: Rubber T off LIM slipped off/dry rotted.
  13. #13 Re: lean condition...
    Mar 2013
    maryland
    Thank you all for your responses! I have replaced all vac lines including the T on the lim under the sc snout. Map is a steady 9.7 at idle. I am going to check the map and egr tube. I also have smoke that comes from the area nelow the egr after the car heats up. I always attributed the smoke to an oil leak i have but now that i think about it the smoke smells and looks more like exhaust smoke than burning oil. This leads me to think the egr may in fact be cracked. I am going to investigate some more romorrow but everyones suggestions have neen great! Keep them coming and i will continue updating while trying to solve this problem because it really is crippling my performance and my wallet given the price of 93you octane!
  14. #14 Re: lean condition...
    Mar 2013
    maryland
    Just an update i scanned the car and here are some results:
    Map: at idle between 8.7 and 9.8hg at 2000rpm right about 8.0hg
    Maf: .52 lb/m. At 2000you rpm 1.4lb/m
    coolant temp 207
    Iat 118
    Ign advance 22.0 at idle 30.5 at 2000rpm
    Stft% -1.2 to. 8 at idle -.8 to 2.3 at 2000rpm
    Ltft% 10.9 at idle 7.0 to 8.3 at 2000rpm very odd never seen them this low
    Absolute tps% 3.9 at 2000rpm
    02s11 .1-.8v at idle. 1-.8 at 2000rpm
    Stft11% -3.8 toto 3.4 at idle-4.6 to 7.3
    O2s12 .14 to. 618 at idle slow smoothe rising and falling. .160 at 2000rpm
    All tests were done in park. Have never seen the ltft so low.
    Had several dtc's: p0171 bank1 too lean intermittent. P0741 tcc solenoid. P1646 boost control solenoid. P1811 max adaptive long shift.
  15. #15 Re: lean condition...
    Feb 2013
    37.295091, -121.930053
    Sounds like what mine was doing. Im in the middle of finding a new engine. But I bought mine as a "fixer upper" the head was also leaking on both sides. But I wish you the best of luck!
  16. #16 Re: lean condition...
    Mar 2013
    maryland
    Do you have the tranny codes as well? I believe the lean condition is related to the egr... i just did the heads as well. The tranny codes are from a bad tcc solenoid and a need for a shift kit haha
  17. #17 Re: lean condition...
    Mar 2013
    maryland
    Just an update... i did what bill suggested and tested the map and it seems to be working. I scanned again and the ltft was 16.4. At idle but goes down when throttled. The code is also intermittent and only in bank 1. Im really stumped guys the egr seems fine but map is now 10that in/hg. Im really stuck performance and mpg are terrible
  18. #18 Re: lean condition...
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    I'm having the same issues you are right, been working on my car all weekend and just want the damn thing to run right, ltft are at 16.4 at idle. I replaced the lower intake manifold gasket today and some vac fittings that were dry rotted. I got it to idle smooth but I took it out for a test drive and it still wont pull over 4000rpm. Any pointers are greatly appreciated!
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  19. #19 Re: lean condition...
    Mar 2013
    maryland
    Any idea what your map reading is?
  20. #20 Re: lean condition...
    Ok.. have you seearched on my name and P0171 yet? If not.. I'd suggest it. Lot's of good info on that code.
  1. fixed the p0171 lean condition
    By Erik Adam Rodriguez in forum General Tech Discussion
    Last Post: 01-27-2013, 10:00 PM
  2. lean
    By illy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2012, 07:40 AM
  3. GTP lean condition
    By gerhardt02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2009, 07:55 PM
  4. lean condition code
    By TDCRacing in forum PCM Tuning
    Last Post: 05-06-2008, 07:12 PM
  5. 940 WOT o2 is lean?
    By Bio248 in forum PCM Tuning
    Last Post: 03-04-2008, 05:55 PM
