Thread: Cam specs?
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 63
  1. #1 Cam specs.
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    A sticky may be in order.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Interesting desktop dyno comparison
    St Louis MO
    This a a desktop dyno from PRJ.
    Cam specs? Attached Files
    2010 Camaro SS LS3
    looks pretty similar to most peoples dyno's where the power peaks around 6k and falls off hard afterwards. Looks like the vs and the xp are pretty close. What version desktop dyno is that? I downloaded one and played with it some but didnt get to many numbers right. Their are alot of parameters i need to change that i dont know what to change to.
    Aurora, Colorado
    If I can retrieve the hard drive from my other laptop, I had a list going. I will see what I can find.
    St Louis MO
    Thanks to Rick (TooMch) for supplying me with an Excel spreadsheet with the following cam specs.
    Cam specs? Attached Images
    2010 Camaro SS LS3
    St Louis MO
    Scott Cook gets credit for this.
    Normally Aspirated Camshafts
    Description Duration @ .050" Lobe Lift L.S.A. Centerline
    Stock L36/L26: 182/192 .258/.258 N/A N/A
    CompCams 76-800-9: 192/200 .300/.310 110 N/A
    CompCams 76-801-9: 200/206 .310/.300 112 N/A
    Grand Prix Store L36: 206/212 .320/.325 113 110
    ZZP GT1: 210/210 .317/.317 113 N/A
    Super Six L36: 210/214 .281/.281 112 N/A
    INTENSE Stage 1 N/A: 212/204 .322/.298 113 109
    INTENSE Stage 1X N/A: 212/216 .327/.321 113 109
    ZZP GT2: 216/216 .317/.317 111 N/A
    INTENSE Stage 2 N/A: 222/224 .337/.327 112 108
    INTENSE Stage 3 N/A: 222/230 .339/.331 110 106
    ZZP GT3: 224/224 .335/.335 113 N/A
    Power Adder Camshafts
    Stock L67/L32: 182/192 .258/.258 115 N/A
    GPS L67 Cam 1: 200/212 .315/.325 115 N/A
    Stattama ST1: 206/206 .320/.320 111 N/A
    ZZP VS: 206/216 .320/.317 115 N/A
    ZZP HL/GPS L67 Cam 2: 206/218 .320/.330 115 N/A
    INTENSE Stage 1 Blower: 209/204 .305/.298 113 108
    CompCams 76-802-9: 210/220 .320/.320 115 N/A
    INTENSE Stage 1X Blower: 210/221 .321/.329 115 111
    INTENSE Stage 1X Turbo: 211/204 .323/.320 116 110
    Stattama ST2: 212/212 .325/.325 112 N/A
    ZZP XP: 212/224 .325/.335 116 N/A
    INTENSE Stage 2 Turbo: 214/206 .331/.320 116 110
    INTENSE Stage 2 Blower: 214/222 .332/.338 115 111
    ZZP XPZ: 217/225 .352/.333 116 N/A
    Stattama ST3: 218/212 .330/.325 113 N/A
    Stattams SS4: 218/230 .330/.340 116 N/A
    IPS Stage 5/ZZP NIC: 220/230 .317/.317 112 N/A
    INTENSE Stage 3 Nitrous/Blower: 220/232 .337/.351 116 112
    Thrasher Race: 222/222 .354/.354 114 N/A
    INTENSE Stage 3 Blower: 222/228 .338/.344 115 111
    INTENSE Stage 3 Turbo: 223/214 .338/.332 116 110
    Stattama ST4: 224/218 .335/.330 116 N/A
    INTENSE Stage 4 Turbo: 226/218 .343/.346 116 110
    INTENSE Stage 4 Blower: 235/238 .375/.376 116 112
    2010 Camaro SS LS3
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    Great Info here. Stickied!
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    This thread is awesome. It makes it easy to help decide on cams.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  9. #9 Re: Cam specs?
    SE Level Member Sinister Drag Designs's Avatar
    missing one
    stattama STR3 224/224 359/354 115
    GVL
    574/566
  10. #10 Re: Cam specs?
    hangover park IL, in the garage working on one of 12 3800's
    Quote Originally Posted by my97gtp View Post
    looks pretty similar to most peoples dyno's where the power peaks around 6k and falls off hard afterwards.....
    thats not because of camshaft design...thats the drawbacks of the shortdeck/shortrod SII
    it severly hampers high rpm breathing...but is excellent for low/mid rpm Tq which is what GM wanted.
  11. #11 Re: Cam specs?
    lapeer michigan
    i was told also that i think in like 99 and newer they have 1.66 rockers from the factory so add .020 to your lift numbers if your 99 or newer....
  12. #12 Re: Cam specs?
    Apr 2008
    sacramento ca
    so did you use just @50 specs?
    i got the seat to seat duration specs for the vs, xp, and s1x too they all pull pretty hard until 7k
    im using desktop dyno 2003
  13. #13 Re: Cam specs?
    Donating Users blowfishRus6's Avatar
    g.a.
    okay well i have a question..i dont really get duration and all that. my question is what will 1.9 rockers do to a stock cam. i noticed were it said rockers with the stock cam but it was all the same..can some one enlighten me??
  14. #14 Re: Cam specs?
    Saraland Alabama
    rockers on a stock cam make the valve open further, it will not change anything else that can help power (duration is the time the valves are open, overlap is the amount of time both valves are open both effect power) to me rockers are a poor mans cam, to do it right you replace the cam (my opinion only)
  15. #15 Re: Cam specs?
    g.a.
    okay, i see. are rockers safe to use for an extended amount of time?? i would asume so. and how do you install a cam. do you have to remove the whole topend or can you go in threw the side?? does the engine need to be pulled out for this??
  16. #16 Re: Cam specs?
    Saraland Alabama
    I don't see a way to pull the cam with the engine in the car completely as the inner fender is in the way, you pull the intake, and rockers leave the heads on unless there is a problem that needs addressed, rockers should be fine as long as the rest of the engine is in good condition (if the oil hasn't been changed since it was new don't try and add power basically)
  17. #17 Re: Cam specs?
    g.a.
    okay..so i gotta pull the engine to put a cam in?? i cant like jack one side up really high, remove the suspension and acess it that way?? problew not but figured id ask. a cam would be nice but i dont have the means to pull the motor
  18. #18 Re: Cam specs?
    Barksdale AFB, LA
    Cam install with the engine in isn't bad. You remove everything but the heads/exhaust manifolds (so you can remove the lifters). Remove the lifters...
    Then, open up the front and remove the cam. Tons of people have done it on the motor still installed, just go through the wheel well. I've never heard of someone pulling the engine just to install a cam.
    Pulling the engine isn't much worse than that, though. All you'd need to do is detach a few cables, hoses, and manifolds then unbolt the flywheel and lift.
    2009 Subaru Impreza WRX STI
  19. #19 Re: Cam specs?
    Bastard Reptile's Avatar
    Kansas City, MO
    You have to losen all 4 cradle bolts, then drop the passenger side...but you have to be careful not to let it down too far or you'll pop your steering shaft loose.
  20. #20 Re: Cam specs?
    g.a.
    ouch maybe i will just stick with rockers
  1. 3800 Torque Specs [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 08-24-2013, 01:24 AM
  2. National Auto Glass Specs (NAGS) Part Numbers - Grand Prix [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 10-16-2011, 11:55 PM
