Thread: Cam specs?
Results 41 to 60 of 63
  1. #41 Re: Cam specs?
    Charles City, IA
    No it wont blow up, but it will not run like it should.
    SMGPFC Two Nipple General
  2. #42 Re: Cam specs?
    SE Level Member 1998DaytonaPaceCar's Avatar
    Dec 2010
    Lawton / Fort Sill, OK
    what about the intense s1x with the new timing chain? any good?
    1998 Daytona Pace Car #1371 of 1500
    Mods: Pacesetter headers, 3.4" S/C pulley, 180º t-stat, K&N FIPK Intake kit, Cross drilled rotors, 18" rims, DHP PCM, Custom exhaust (Cherry Bomb glasspack acting as resonator, 2X Corsa sport mufflers from my old 06 GTO R.I.P.)
  3. #43 Re: Cam specs?
    yes
  4. #44 Re: Cam specs?
    Dec 2010
    is this something i could use hp tuners to tune myself or would i have to get a expensive dyno tune cause the closest dyno i know of is in tulsa (almost 4 hours away)
  5. #45 Re: Cam specs?
    if you have HPT all you need is a wideband and you're set.
  6. #46 Re: Cam specs?
    Dec 2010
    what company makes a decent one?
  7. #47 Re: Cam specs?
    NGK or any of the bosch sensor ones.
  8. #48 Re: Cam specs?
    Omaha, NE
    Quote Originally Posted by 1998DaytonaPaceCar View Post
    The Innovate Motorsports LC-1 is a good wideband and can be found for a good price.
    I just read this thread for the first time, great info
  9. #49 Re: Cam specs?
    SE Level Member ray4was's Avatar
    Buffalo, New York
    I am on here reading to much stuff at one time so... from what i have read i can get away with just swaping cams for a VS cam on a stock vavletrain...? Im kinda confused
  10. #50 Re: Cam specs?
    You'd at the very least want new valve springs.
    preferably L76 springs. Not LS6 springs.
  11. #51 Re: Cam specs?
    Buffalo, New York
    Ok so I can get away with the VS cam with alittle better springs... sounds good to me now I just got to find springs and a cam
  12. #52 Re: Cam specs?
    SE Level Member sd98gtp's Avatar
    Sioux Falls, SD
    i picked up a PRJ LL for my new L26 based motor and didn't see any specs on the cam in this thread (or its possible i missed them, in that case my bad)
    PRJ LL Cam
    Duration @ .050" 214º/220º
    Intake Lift .305" (1.6 Rockers .488, 1.8 Rockers .549)
    Exhaust Lift .285" (1.6 Rockers .456, 1.8 Rockers .513)
    ICA: 113°
    LSA: 114°
    1997 Dodge Avenger ES~ Black on Black
    1998 Forest Green GTP- L26, PRJ LL, Crow 105's, SD Headers,Wizaird CAI,gen 3w/ 3.4, custom chipped pistons mod= Sold
  13. #53 Re: Cam specs?
    SE Level Member Lil larry's Avatar
    Nov 2012
    Elkview, west virginia
    What about the nic cam
  14. #54 Re: Cam specs?
    SE Level Member CountryBoy's Avatar
    Jan 2013
    Lima Ohio
    okay so after reading this I'm a little confused,what would be the best cam for a car i want to daily drive but also run hard at the track on weekends? I dont understand the specifications of the cams,but I understand what they do and what the performance gains are. Any suggestions??
    Got Boost?
  15. #55 Re: Cam specs?
    Quote Originally Posted by CountryBoy View Post
    Pretty sure that is covered...everywhere.
  16. #56 Re: Cam specs.
    Ohio
    If you don't understand the specifications then you don't understand what they do.
  17. #57 Re: Cam specs.
    Jan 2013
    Lima Ohio
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    I understand what a cam does and the performance gains that come with it,I just cant quite decyfer the correct way to read the specs. I'm new to this kind of thing and i would rather figure this stuff out on my own and build a car than pay someone to build my car for me.
    Got Boost?
  18. #58 Re: Cam specs?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Not sure if I should ask this here or somewhere else, but what do stock heads limit you to? I know its somewhere in the 500 range, but was curious if anyone knows exactly what lift numbers are max for stock heads.
    04 GTP -HAI, 1.9 rockers.
  19. #59 Re: Cam specs.
    Sep 2017
    Arizona
    So remove the rocker arms and push rods do u have to pull the lifters out to install zzp vs cam
    Sent from my LGMS550 using Tapatalk
  20. #60 Re: Cam specs?
    If you don't take the lifters out they will fall into the motor or can fall into the motor.
    I don't think there are holes to put dowel rods in to hold the lifters up but I forget.
  1. 3800 Torque Specs [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 08-24-2013, 01:24 AM
  2. National Auto Glass Specs (NAGS) Part Numbers - Grand Prix [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 10-16-2011, 11:55 PM
