Thread: Cam specs?
Results 21 to 40 of 63
  1. #21 Re: Cam specs?
    SE Level Member lageR's Avatar
    Jan 2009
    IL
    Quote Originally Posted by whitcomb View Post
    i was told also that i think in like 99 and newer they have 1.66 rockers from the factory so add .020 to your lift numbers if your 99 or newer....
  2. #22 Re: Cam specs?
  3. #23 Re: Cam specs?
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    so stock is 1.6? also, i could reuse my lifters on a new cam if they are same grade material and in good condition right?
  4. #24 Re: Cam specs?
    Banned - Busted For Scamming
    Feb 2009
    yes
  5. #25 Re: Cam specs?
    Jan 2009
    san diego
    yes to all questions? lol...if so awesome. i seen them reuse stock rollers off of a 5.0 on horsepower, but they were very particular on making sure the bearings and everything in the lifters were thouroughly checked. i hear is a good way to budget since this economy is sucking!!!
  6. #26 Re: Cam specs?
    there are no 1:1.66 ratio rockers. that is stupid.
    Actually GM has quoted that some of the L67 motors had 1.60:1 and some had 1.66:1...I'll have to find it in my laptop when I get home because I'm working right now...
  7. #27 Re: Cam specs?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    AFAIK, it's the same rocker, GM just started labeling them differently.
    2001 Buick Regal LS - Almost Stock
  8. #28 Re: Cam specs?
    Quote Originally Posted by Scimmia View Post
    Go figure...GM being consistent about something right?
  9. #29 Re: Cam specs?
    Vancouver, WA
    This is where the "factory freaks" come from
  10. #30 Re: Cam specs?
    Quote Originally Posted by footballplaya3k View Post
    factory freaks were not because of 1.66:1 rockers. 1.66:1 rockers do not exist.
  11. #31 Re: Cam specs?
    It doesn't. Maybe you should just stick to football.
  12. #32 Re: Cam specs?
    Vancouver, WA
    Okay dickweed
  13. #33 Re: Cam specs?
    Ok Farve.
  14. #34 Re: Cam specs?
    MA
    farve sucks
    SMGPFC Member #9
  15. #35 Re: Cam specs?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    favre?
  16. #36 Re: Cam specs?
    NO trashing MN damn it
  17. #37 Re: Cam specs?
    Minnesota
    Quote Originally Posted by 02GrandPrixIraqVet View Post
    This lol
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  18. #38 Re: Cam specs?
    MA
    hes right, we shouldnt bash on them, the saints did that enough already
    SMGPFC Member #9
  19. #39 Re: Cam specs?
    SE Level Member 1998DaytonaPaceCar's Avatar
    Dec 2010
    Lawton / Fort Sill, OK
    was thinking about getting this cam: http://www.pfyc.com/p/WB3020/Comp+Ca...tegory_Code=GP after the cam is installed, tuning is mandatory correct, (will the motor blow up with dhp shelf tune)
    1998 Daytona Pace Car #1371 of 1500
    Mods: Pacesetter headers, 3.4" S/C pulley, 180ยบ t-stat, K&N FIPK Intake kit, Cross drilled rotors, 18" rims, DHP PCM, Custom exhaust (Cherry Bomb glasspack acting as resonator, 2X Corsa sport mufflers from my old 06 GTO R.I.P.)
  20. #40 Re: Cam specs?
    Quote Originally Posted by 1998DaytonaPaceCar View Post
    after a cam is installed, tuning is mandatory correct, (will the motor blow up with dhp shelf tune)
    tuning is fairly manditory, but your car will more than likely run without a tune. it will just run poorly.
    however, i would probably shoot for a different cam than that one. there are better choices (s1x, xp, vs).
  1. 3800 Torque Specs [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 08-24-2013, 01:24 AM
  2. National Auto Glass Specs (NAGS) Part Numbers - Grand Prix [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 10-16-2011, 11:55 PM
