Thread: Hopefully not supercharger!! engine noise w/ vid
Results 1 to 11 of 11
  1. #1 Hopefully not supercharger!! engine noise w/ vid
    Jan 2013
    Grand Rapids, Michigan
    Gtp noise - YouTube I had coolant elbows done on the 20th of December but haven't touched the SC since I bought it... 80,000 miles ago.
  2. #2 Re: Hopefully not supercharger!! engine noise w/ vid
    Jan 2013
    Sorry, not the best vid
  3. #3 Re: Hopefully not supercharger!! engine noise w/ vid
    antioch ill
    supercharger coupler maybe not sure
  4. #4 Re: Hopefully not supercharger!! engine noise w/ vid
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    it is so hard to pin point such a noise, sc coupler, idler pulley....either way these should be fairly easy
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  5. #5 Re: Hopefully not supercharger!! engine noise w/ vid
    Jan 2013
    and now its sprinkling coolant from somewhere throughout the belt assembly
  6. #6 Re: Hopefully not supercharger!! engine noise w/ vid
    Quote Originally Posted by sickhix04 View Post
    My guess is the coolant elbow.
  7. #7 Re: Hopefully not supercharger!! engine noise w/ vid
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    water pump is bad
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  8. #8 Re: Hopefully not supercharger!! engine noise w/ vid
    GT Level Member Toms04compg's Avatar
    Michigan
    If coolant elbows aren't cracked/leaking check water pump... take off belt and wiggle it if it has play its probably bad. Try the stethoscope method for knock... buy one or use a long screwdriver metal end on spot to test put your ear to handle. Just watch where you put it.
  9. #9 Re: Hopefully not supercharger!! engine noise w/ vid
    Tom..you like that stethescope, don't you?
  10. #10 Re: Hopefully not supercharger!! engine noise w/ vid
    Jan 2013
    yup water pump
  11. #11 Re: Hopefully not supercharger!! engine noise w/ vid
    Jan 2013
    thanks ya'll
  1. Noise from near supercharger
    By jmackisback in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2012, 12:29 AM
  2. supercharger noise?
    By Owen Shoopman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2012, 09:21 AM
  3. noise from supercharger
    By johndoe35652 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 02:22 AM
  4. Engine noise Supercharger??
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2009, 04:45 PM
  5. Noise in the supercharger
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 06:58 PM
