Thread: Fuel Mileage
Results 21 to 40 of 54
  1. #21 Re: Fuel Mileage
    Bunnell, FL
    yesterday i hypermilled it from work to home and got 36 average for the trip
    I'm a Sex Offender
  2. #22 Re: Fuel Mileage
    SE Level Member illtacticz's Avatar
    Dec 2010
    Columbus, Ohio
    2000 GTP stock minus Spectre Ram Air... I get 33 Highway 19 City
  3. #23 Re: Fuel Mileage
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    How do you guys find your fuel mileage since I'm almost certain my dic isn't correct and doesn't move much.
  4. #24 Re: Fuel Mileage
    Quote Originally Posted by Xanthous View Post
    Use math?
    O_o
  5. #25 Re: Fuel Mileage
    miles driven / fuel used.
    like 100 miles/ 5 gallons = 20 mpgs.
  6. #26 Re: Fuel Mileage
    thxgai.
  7. #27 Re: Fuel Mileage
    thxgai.
    I got you bro.
  8. #28 Re: Fuel Mileage
    Bunnell, FL
    how accurate is the dic for fuel used?
    I'm a Sex Offender
  9. #29 Re: Fuel Mileage
    its been .5 to 1.5 gallons off befor for me anyways, letting the car idle for long periods of time tend to have an affect.
  10. #30 Re: Fuel Mileage
    Grand Rapids, MI
    mine tends to be pretty accurate. usually do manual math when i fill up and its either dead on or a hair off.
  11. #31 Re: Fuel Mileage
    you need to fill your tank, set the trip on the cluster, then drive the tank to 1/4 tank, or where ever you refill it at, then fill the tank again, take the gallons from the gas pump ( that you just put in) and divide it by the miles driven. that will be your mpg.
  12. #32 Re: Fuel Mileage
    Midget Amputee Fortehluls's Avatar
    Nov 2011
    New York
    According to the computer I get around 27-28 Highway (72 MPH cruise) , and Avg MPG also according to the computer is 21.2. Only mods are CAI.
    2004 Comp G mods:Plog, 10.5mm wires, 3.6 pulley, Full ZZP 2.5" catback, Overkill tune.
  13. #33 Re: Fuel Mileage
    GTP Level Member buickman104's Avatar
    NYC
    I get 13 city/ 32 Hwy, but I do live in NYC so my city miles are more unfair than what most consider city driving. Today it took me 3 hours to drive 48 miles in the city area during rush hour.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  14. #34 Re: Fuel Mileage
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Mine sucks so bad on the highway I get like 22 what the hell is wrong with my CAR??? Is it my lower thermostat
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  15. #35 Re: Fuel Mileage
    Nov 2011
    New York
    Quote Originally Posted by jacobmh27 View Post
    Problem is you need MOAR BOOST!@!@!@
  16. #36 Re: Fuel Mileage
    Naugatuck CT
    More Boost. I have a 3.4 on there now. I just actually did he math this morning and I am geting 21.33 on mostly highway. I think that is pretty ****ty. I thought it used to be a lot better. I do not know what the hell happened.
  17. #37 Re: Fuel Mileage
    Grand Rapids, MI
    I have a 3.4 and I'm getting a decent 27-28 on strictly highway. So I would assume my mixed economy would be something around 21 just guessing. Next time I fill up I will track it
  18. #38 Re: Fuel Mileage
    Florida
    i see you have an AF gauge... what is your LTFT? and yes with a 160 your prob not getting up to temp and running more fuel then needed. swap to a 180 at min and possibly the 195 for winter. even down here in FL i dont recommend a 160. i ran on on my Z when my trany was bad, as when the trany got to 185 it would slip. so the 160 gave me more time to keep it from slipping and also this is on the DOHC that had AL heads that cooled better then our iron heads.
    to the OP. the Comp G has 3.29 gears vs the GTP's 2.92's... this will hurt HW mpg and may help in town. the gear swap helps low end acceleration.
  19. #39 Re: Fuel Mileage
    Out West
    Quote Originally Posted by brandonl2000 View Post
    I get 24-29 Highway with my heavy ass steel 18's
    In town, and i mean strictly in town i can coax 23mpg out of it keeping it under 2500 rpm. This is with stop and go. Again with the 18's.
    I have a couple more mods than you though and run a stupid amount of timing as the great equalizer.
    Whine with your Cheese?
  20. #40 Re: Fuel Mileage
    Grand Rapids, MI
    wish we could have gotten work with my cruise timing
  1. The alt rewire mod actually DOES increase fuel mileage!!
    By DanGTP in forum General Tech Discussion
    Last Post: 04-12-2012, 07:31 AM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Need better gas mileage
    By bayareagtp in forum Off Topic Discussion
    Last Post: 12-02-2008, 12:40 AM
  4. CEL and terrible gas mileage
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 10-06-2008, 04:30 AM
  5. Gas Mileage
    By TCO in forum Off Topic Discussion
    Last Post: 05-07-2008, 11:01 AM
