Thread: Problem with Idle after Supercharger Rebuild
Results 1 to 15 of 15
  1. #1 Problem with Idle after Supercharger Rebuild
    Mar 2012
    Southeast Indiana
    I rebuilt my blower, and snout over the past couple weeks, and put in some new stock injectors which solved my 6th cylinder misfire problem. I also switched out some of the vaccum lines with some I had purchased from ZZPerformance. Now the car sputters like a cammed out muscle car between 750 and 1000 RPM bu..bu..bu...bu, and it wont read boost on the center led display, but the car drives and pulls just like it use to so I'm confused. I can hear a hiss near the boost bypass valve so I swapped it out and its still doing the same thing and I checked all of the vaccum lines. Please help
  2. #2 Re: Problem with Idle after Supercharger Rebuild
    Sounds like you left the map sensor disconnected from the vacuum line. It's in back of the charger.
  3. #3 Re: Problem with Idle after Supercharger Rebuild
    check the fat vac hose from the top of the TB, it loops back to the evap on the back of the engine, you cant always see the crack but can hear it.
    after i did my lim job mine broke, did the same thing. sounded like it had a big cam.
  4. #4 Re: Problem with Idle after Supercharger Rebuild
    Mar 2012
    Southeast Indiana
    Dang you guys are good I unbolted the MAP sensor and didn't even notice the vacuum Line, where does the other end of that vacuum line go is my other question?
  5. #5 Re: Problem with Idle after Supercharger Rebuild
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    nipple under the snout
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  6. #6 Re: Problem with Idle after Supercharger Rebuild
    Remember that T under the SC snout, it should go from that T to the map sensor.
  7. #7 Re: Problem with Idle after Supercharger Rebuild
    Mar 2012
    Southeast Indiana
    Alright so what does the other sensor back by the MAP sensor connect too?
  8. #8 Re: Problem with Idle after Supercharger Rebuild
  9. #9 Re: Problem with Idle after Supercharger Rebuild
    What year are you?
    If you have two map sensors, one stays open, one gets a vac line. Otherwise..the other dealio is the evap or california emission bs
  10. #10 Re: Problem with Idle after Supercharger Rebuild
    Mar 2012
    Southeast Indiana
    Its a 1998 I took a picture of it, how do I post it into this thread?
  11. #11 Re: Problem with Idle after Supercharger Rebuild
    You load it to a hosting site like photobucket and then link it in
    It'll have a red electrical connector ...that's evap.
  12. #12 Re: Problem with Idle after Supercharger Rebuild
    Mar 2012
    Southeast Indiana
    Check out this photo from Snapbucket: ? Sensor On Back Of SC Photo by ectrojan1918 | Photobucket heres what im talking about whats the left side connect to?
  13. #13 Re: Problem with Idle after Supercharger Rebuild
    Pissed myself about the gloves.
    That's evap. See the diagram above where the line leaves the evap and goes to the throttle body...that's what should be connected to that. Use regular rubber hose to make that connection again.
    Meanwhile..what's it connect to..nothing..it's broken!
  14. #14 Re: Problem with Idle after Supercharger Rebuild
    Mar 2012
    Southeast Indiana
    What's the deal with the gloves?ha $5 bucks at any farm supply store perfect for bailing hay ha, I don't get what is broken I unbolted that, and the vacuum line is off but the barb is not broken. I may sound like an idiot right now but I'm running on no sleep in the past 45 hours
  15. #15 Re: Problem with Idle after Supercharger Rebuild
    the line should be attached to the piece that is attached to the soleniod. No biggie. Reconnect it and smile.
    The gloves caught me off guard. I'd expect to see Bert or Ernie at the other end of those gloves...lol
  1. supercharger rebuild
    By monsterjam5000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2010, 08:12 PM
  2. Supercharger rebuild parts
    By Silver GTP in forum General Tech Discussion
    Last Post: 04-29-2010, 06:19 PM
  3. supercharger rebuild
    By basballny2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2010, 07:54 PM
  4. Where to get a supercharger snout rebuild kit? (bearings, coupler, etc)
    By PCweber in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2009, 11:36 PM
