Thread: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer springs?
Results 1 to 20 of 40
  1. #1 I don't get it, with VS CAM stock springs are fine, but rockers need stiffer springs?
    Jan 2013
    Australia
    G'day from Australia,
    I hope I'm allowed to post here.
    So I've been looking into cams and rockers recently. My car is a GM Holden VT Commodore with L67. Just has basic mods like extractors (you guys call them headers I think lol) twin hi-flow cats and 3.4 inch pulley.
    Anyway, so I was looking at ZZP and saw their VS cam, apparently it designed to work with stock valvetrain components. Yet the lift from that cam (.512/.507" is much higher than the lift that would be obtained from 1.9 rockers on a stock cam (~ .490"). Yet everybody always says 1.9 rockers need new springs.
    Does this make sense or am I missing something? Over here we have many people using YT 1.95 rockers (they're not available in the US) with stock springs with no problems.
    My shift points will not go above 5400rpm, which is redline on our Holdens here... so im wondering are stiffer springs really needed?
    cheers guys
  2. #2 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    I'm running stock springs on my 1.9 rockers. I'd replace the springs while everything was apart if I were you.
  3. #3 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Jan 2013
    Australia
    cheers mate,
    Yea, its just that replacing springs is pretty labour intensive and expensive, and not something i can do myself, dont have the skills or time.
    Eventually I will be getting a cam package with DR chain and 105 springs... just want to know if I can get by with stock springs for maybe a year or so.
    Ohio
    How many miles/kilometers are on the engine?
  5. #5 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Jan 2013
    Australia
    about 160.000km... I think thats around 100.000 miles.
    I bought the engine second hand from wreckers, so I'll have to trust them on that lol
    Ohio
    While yes, you would be safe with stock springs.
    I would replace them with gm l76 springs. They will be a happy medium for springs. Or you could just get 105 springs to give you a window if you ever want a larger cam
  7. #7 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Jan 2013
    Australia
    Yea I'll get that done along with double row timing chain when I get the cam I think.... Ive spoken to a performance shop here and getting DR chain, springs and rockers fitted ends up costing more than their cam package lol.
    I guess Im stuck with just the rockers for now, Ive thought about going the 1.8 ratio to be extra safe.... but the performance gain probably isnt worth the cost with those/
  8. #8 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Bettendorf, IA
    Do the stiffer springs make more valve noise? seems after I replaced my springs, the engine seemed a little noisier.
  9. #9 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Jan 2013
    Australia
    Does anybody actually know what the max lift is on stock springs? And what the stock springs are called lol
  10. #10 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    May 2008
    Schuyler, NE
    Yes, ZZP says it's ok to run stock valvetrain with a VS cam. But, you a loosing power when doing so. And, people do break stock springs with the VS. That's why it's suggested to upgrade them.
    With a VS cam, I wouldn't even think about putting a double timing chain. It's not worth the extra vibration. Get a new stock timing chain, a new chain dampner, and throw on a set of PBM 110# springs.
  11. #11 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Feb 2009
    flintnasty MI
    Swapping in some upgraded valvesprings on a stock timing chain is pretty simple. Any rocker/cam upgrades will gain from them although "required" is a strong statement. On bigger cam setups you are going to need extra room in the valvespring area to allow the cam to lift.
    Also, lift does not play as big of a factor on the required spring strength as duration does. The more duration you have the steeper the cam lobe will be and the more succeptable to floating it is.
  12. #12 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Not entirely true. The lobe geometry is affected by the total lift in relation to the duration. The higher the lift, the further the valvetrain has to move. The shorter the duration, the less time the valvetrain has to move the distance set by the lift.
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  13. #13 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    x2 ^^
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  14. #14 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Banned
    Jan 2013
    Colorado
    I don't get it. If you get a VS cam with retainers and springs do you need to get new rockers?
  15. #15 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    nope
  16. #16 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Banned
    Jan 2013
    Colorado
    But it's recommended?
    No. Reuse your stockers. Only way you'll be having to buy rockers if you wanted something more then the standard 1.6 that come stock. Basically increasing the lift. You go with either a CAM or rockers..not both.
    04 Comp G.
  18. #18 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Unless you do head work then you can do both if you really want
  19. #19 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    The Boss Iceman6669's Avatar
    Jun 2011
    you can do both with milled heads....
    2011 F-150 Yote powered
  20. #20 Re: I don't get it, with VS CAM stock springs are fine, but rockers need stiffer spri
    Banned
    Jan 2013
    Colorado
    I was just thinking a VS cam with new springs and retainers.
  1. getting rockers a springs
    By STEVEGTX in forum General Grand Prix Discussion
    Last Post: 01-02-2013, 10:51 PM
  2. Springs and rockers same between L36/L67?
    By twiztid in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-07-2012, 01:58 AM
  3. 1.8 Rockers, can you use them with stock springs?
    By lafenatu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2012, 11:33 AM
  4. Rockers and springs
    By Sudden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2010, 06:04 PM
  5. Stiffer springs
    By njbrain in forum Brakes/Suspension/Chassis
    Last Post: 11-25-2008, 07:46 PM
