Thread: temp on aeroforce and temp on dash
Results 1 to 13 of 13
  1. #1 temp on aeroforce and temp on dash
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    My temp on my aeroforse scan gauge seems to read about 10 degrees more than the Temp gauge in the dash. Do they mesure at differant points or something
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: temp on aeroforce and temp on dash
    SE Level Member black.gtp's Avatar
    Apr 2008
    Indiana
    mine reads the same way I trust the areoforce cause its reading the PCM
    PRJ Built enough said!!!!
    www.prjperformance.com
  3. #3 Re: temp on aeroforce and temp on dash
    Banned
    oswego
    yeah my aeroforce reads 162-165 and my dash reads like 170-175 so like said before i trust the aeroforce readings. Those are right from the pcm.
  4. #4 Re: temp on aeroforce and temp on dash
    TDCRacing
    Guest
    Like most cars the stock gauges arent to accurate.
  5. #5 Re: temp on aeroforce and temp on dash
    NE Ohio
    my tep gague is way off, i trst the aeroforce, plus if you watch the aeroforce get close to 180* and watch the needle on the dash cluster, it jumps back down once the thermostat opens, however it still doesnt read the right temps.
  6. #6 Re: temp on aeroforce and temp on dash
    Barksdale AFB, LA
    Must be an issue with the GP cluster because mine is spot on.
    2009 Subaru Impreza WRX STI
  7. #7 Re: temp on aeroforce and temp on dash
    SE Level Member jims05ss's Avatar
    Quote Originally Posted by Sabrewings View Post
    Yeah, mine is pretty damn close to being the same on both gauges also.
    05 Impala SS; 13.84 @ 100. SSIC, 3.25 pulley, 1.9's, PRJ tuned PCM, ZZP SS P-log, ZZP SS 3" DP, ZZP TB spacer, 4" FWI w/9" K&N, U-bend & resonator delete, Magnaflow cat, wrapped crossover, 180 t-stat, PRJ Wires, 103's, Royal Purple, Eibachs, front & rear STB's, Aeroforce.
  8. #8 Re: temp on aeroforce and temp on dash
    NE Ohio
    yeah, our temp gauges are worthless.
  9. #9 Re: temp on aeroforce and temp on dash
    Naugatuck CT
    yea that is what I figured Just wanted to make sure
    THanks
    I love this gauge by the way
  10. #10 Re: temp on aeroforce and temp on dash
    Jersey
    my Aeroforce when set to trans temp is around 160* and my autometer electrical trans temp reads 110*, seems like autometer is worthless as well.
    16' wrx sti- stock
  11. #11 Re: temp on aeroforce and temp on dash
    Barksdale AFB, LA
    Quote Originally Posted by 99prixgt View Post
    Depends on where it's being measured. The stock sender is way in the transmission where it matters.
  12. #12 Re: temp on aeroforce and temp on dash
    Jersey
    i installed the sender where the factory threaded port hole is on the top of the transmission, under the throttle body. I didnt think it was to accurate. I would drive for a few hours and the hottest it would get is around 140*. The aeroforce was up around 165ish 170ish. Uninstalled autometer and now just the aeroforce. How would i know if the case learn i did on the aeroforce worked or not?
    16' wrx sti- stock
  13. #13 Re: temp on aeroforce and temp on dash
    Barksdale AFB, LA
    If you don't have a code, it must've worked.
  1. ambient air temp sensor
    By Toasty in forum General Tech Discussion
    Last Post: 09-10-2011, 10:12 PM
  2. Temp fluctuation
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 10-11-2008, 08:28 PM
  3. Manifold Air Temp Guage?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 05:24 PM
  4. Motor Temp Creeping Up
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2008, 06:05 PM
  5. What temp should a 2004 GTP run at when warmed up?
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2008, 11:34 PM
