Thread: Need some help on rebuild
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 66
  1. #1 Need some help on rebuild
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    So i just did a rebuild to my girls car and got a new short block l67 and installed an XP cam and stage 2 heads. I finished putting everything back together and reinstalled the motor and started it yesterday and there was ALOT of loud taping coming from the front head area...in person it is all coming from rockers. I had spare rockers and tried replacing the ones in but still the rockers were really loud. Could something have gotten stick in the cylinders causing this......i think a piece of styrofoam piece may have gotten stuck in cylinder 3 valve area of the heads from when i took them out of the box. But i know for sure its not a lower end knock. No codes but a p0300 misfire code.
    https://www.youtube.com/watch?v=o6bT...e_gdata_player
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
    You verified that the rockers were tightened and torqued to spec?
    04 Comp G.
    Bowie, MD
    Yes I even removed and reinstalled them....got the same results.
    Sent from my SGH-T989 using Tapatalk 2
  4. #4 Re: Need some help on rebuild
    Torqued them to 25 ft pounds
    Bowie, MD
    Ok ill try that
    Bowie, MD
    Don't know if this helps but the heads have 130# springs also.
  7. #7 Re: Need some help on rebuild
    You have reusable bolts right?
    Ohio
    Wait.... Are you telling us, that there is a piece of Styrofoam in the engine.
    The front too... And you're wondering what the tick is?
    Bowie, MD
    Yes I am using reusable arp bolts.
    I am saying there might be because the ported heads came in a box with little Styrofoam pelits like that ones you buy when shipping. I'm not sure if that would cause it I dont know....
    I'm thinking of removing the front head and checking but will I have to buy a new head gasket? The current one is brand new.
  10. #10 Re: Need some help on rebuild
    Styrofoam wouldn't last long in the motor. It's not that
  11. #11 Re: Need some help on rebuild
    Leave the head on. It's not your issue.
    How long was the motor running when you took this vid? Sounds a lot like lifters that haven't pumped up. Did you soak them in oil before installing, were they new, stock pushrods?
    Bowie, MD
    Lifters were used and no I didn't soak them before installing them....I didn't think I needed to because they were kind of oily when I installed them from the bag I kept them in. The pushrods are stock and the motor was running for a few minutes before i started recording....
    Hows it drive?
    Are all of the valves openening when you tighten the rockers down? Or just some?
  14. #14 Re: Need some help on rebuild
    Bowie, MD
    I havent driven it....i just actually started it up yesterday and put everything else on pause because of the loud ticking....i believe all
  15. #15 Re: Need some help on rebuild
    Bowie, MD
    So i let the car idle some more a little longer to see if that would help get rid of the tapping and turned the car off......then when i tried to start it back up the car wouldnt start back up....it would just keep cranking smfh....what now....
  16. #16 Re: Need some help on rebuild
    Answer my second question.
    You might have junk lifters.
  17. #17 Re: Need some help on rebuild
    Bowie, MD
    I wasnt really paying attention when i tightened them down...i only focused on the rocker bolts being tight...should i recheck?
  18. #18 Re: Need some help on rebuild
    Bowie, MD
    The lifters i installed were from the junkyard off a 97 regal gs.....i still have my old lifters....should i try installing those?
  19. #19 Re: Need some help on rebuild
    I wouldn't condemn then until you check to see whats going on.
    Mine locked up and held all of the valves open. Very easy to spot once the valve covers off.
  20. #20 Re: Need some help on rebuild
    Bowie, MD
    ok ill pop open the front valve covers and check
  1. Top End Rebuild
    By MrPhotographer06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2011, 04:21 PM
  2. Top end rebuild
    By eganz84 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2011, 03:16 PM
  3. Done with my rebuild!!
    By Shang TI in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2011, 05:43 PM
  4. m90 rebuild
    By 91z in forum General Tech Discussion
    Last Post: 09-02-2010, 05:58 PM
  5. to rebuild or not to rebuild
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2009, 04:14 PM
