I am installing a PLOG in my 99 GTP and when it's bolted on, the bottom corner of the PLOG contacts the A/C compressor. Is this normal? The engine is completely stock. It looks like that could heat up the A/C compressor and cause it to fail.
I removed the plog and ground down the top of the A/C compressor slightly. Now there is enough clearance to slip a piece of paper through. About 1/16" to 1/8". Attached are the pictures. The first one is infront of the car looking down at a mirror to see the clearance. The second and third are without the mirror.
I guess I can't post the pictures.
Create a photobucket account to host our photos.
Tried to create a photobucket account but it is not working. Their web page is not working right. I did drive it and it doesn't seem to be making the A/C compressor hot. But it seemed to have an opposite affect with my knock retard. I had a high of 7.5 knock retard with the original manifold. After putting on the PLOG, it peaked out a 12.5 knock retard. It seems to have made things worse.
email your pic to billboost37 at gmail dot com and I'll post it for you.
Compressor shouldn't be that close to the exhaust.
Thanks Bill. I just sent you an email with the three pictures.
waiting on phone to load them up. Looks like a ZZP flaw on it.
The end of the log is touching the back end of the compressor for those of you at home.
zzp has ****y quality control because the plog I have is also made wrong, the flange is welded on backwards
Just an update. I also purchased the 3" SS downpipe and installed it today. I broke one of the bolts off that attaches it to the muffler and couldn't drill it out so I will have a muffler shop remove it tomorrow. But when I took it for a spin, I didn't have any knock retard at any speed. When I tried it out with just the PLOG, it was getting high knock retard. The PLOG so far doesn't seem to heat the A/C comressor up, since I ground down enough of the compressor that it's not touching.
After seeing this, I went and looked at my Plog as well and it is very damm close to the Compressor, not hitting since I could still bolt it on fine but I wouldnt be surprised if there is 1-4mm of clearance between at most..
couldnt it in theory be hitting your ac compressor then when the motor rocks causing a possible false KR? Also why do people even buy powerlogs? Its like 50 bucks more to get cheap headers and a lot more performance..
Max,
Both the A/C compressor and the exhaust manifolds are attached to the engine block, so they should both move togther when the engine rocks. The reason I chose the powerlog is because I knew I could intall it and the downpipe myself. I would have to pay someone to install headers making them more expensive. The "lot more performance" is debatable for those who don't plan on doing much more modifications. If I felt comfortable doing the headers myself, I definately would have gone that route.
The reason for the purchase for me was the black friday deal that went on, and my crazy plans of turboing it that I have decided against for now. I will be going headers in the next few weeks.
As for the plog, I will check today in a little bit, my father is using the garage at the moment.
