Thread: engine swap question!!!!
Results 1 to 8 of 8
  1. #1 engine swap question!!!!
    Aug 2008
    oharr
    Ok so I've decided to replace my whole engine due to the fact that it already messed up on me and it already has over 150,xxx miles on it.....now my question is will a newer engine like the comp g or anything around that area fit in my car or should I just stick to the year of my car and find an engine like the one I have .....and where would I be able to find a good engine? Thanks in advance to anybody who can give me some info
  2. #2 Re: engine swap question!!!!
    Barksdale AFB, LA
    Easiest solution is a drop in replacement. You have a Series II supercharged, find a Series II supercharged.
    2009 Subaru Impreza WRX STI
  3. #3 Re: engine swap question!!!!
    Aug 2008
    oharr
    Ok and do yall know where I can find a good motor or a cheap one that doesn't have a lot of miles
  4. #4 Re: engine swap question!!!!
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by 98bdgtp View Post
    Local junk yard.
  5. #5 Re: engine swap question!!!!
    Barksdale AFB, LA
  6. #6 Re: engine swap question!!!!
    Aug 2008
    New Jersey
    GM performance parts? They sell 3800 crate engines. Not necessarily cheap, but it wont have any miles on it...
  7. #7 Re: engine swap question!!!!
    miles have nothing to do with how the motor runs. i bet some of us on here have 150k mile cars that run awesome because we did regular maintenance.
    id find anything less than 75k miles in a junkyard and call it good. and there is no reason why you wouldnt install some other goodies while the motor is out. realisitically if you needed anything it would be just the block. i bet your heads and up are just fine.
  8. #8 Re: engine swap question!!!!
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    on my GTP, i had 240,000 miles on the OG engine, never had issues but i kept up on my maintenance, i got rid of the car years ago though
    if you were wanting to go series 3 engine you'll gain 20 horses just in the swap but not really worth it for the cost
    stick with the series 2
    check around at junk yards, morad is good but they can be pricey
    COMP G
  1. Engine swap
    By BankRupt in forum Off Topic Discussion
    Last Post: 07-19-2008, 11:06 AM
  2. engine swap
    By 3800John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2008, 02:53 PM
  3. Help!! Tranny Swap Engine ''Refresh''
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-10-2008, 12:04 PM
  4. Swap 3.8 (L67) into 3.1 engine compartment?
    By jerricho in forum General Tech Discussion
    Last Post: 05-17-2008, 12:07 AM
