Thread: Dampener with double roller
Results 1 to 12 of 12
  1. #1 Dampener with double roller
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Should a dampeners be used with a Double roller?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Dampener with double roller
    No, the point of the double roller is a dampner is not needed.
  3. #3 Re: Dampener with double roller
    Bowie, MD
    Oh ok. my mistake.
  4. #4 Re: Dampener with double roller
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I went through that when I installed mine and got this answer from intense... I did bend the spring ever so slightly so it wasn't as much tension on it.
    The chain damper is a touchy subject; I do believe the damper is needed with any chain mainly because I have seen a few instances where people got engine damage from not running one, but I am aware that the do have a shorter life when used specifically with the double chain. It’s hard to give you a life expectancy because sometimes they only last a few weeks while other times they last years, most of the wear people see happens when the engine is still fresh and the chain is tight, once the chain gets some miles on it and stretches a bit wear is significantly reduced. Generally I recommend you break in the engine and drive it for a short time (a few weeks should do) then change out the damper.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  5. #5 Re: Dampener with double roller
    Never Never Land
    Yea no dampener with a double roller.
  6. #6 Re: Dampener with double roller
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    interesting question.
  7. #7 Re: Dampener with double roller
    Bowie, MD
    Ok i just broke everything back down and removed the dampener
  8. #8 Re: Dampener with double roller
    Feb 2010
    Oklahoma City, OK
    It's mainly there to keep the crank and valve in time when the chain stretches, but another big reason is chain slap. When the chain stretches it can flip around kinda violently(chain slap) and that causes even more stretching and premature wear. Or breakage as I've seen a lot of double rollers do way before their stock single chains with tensioners have. Mine has been in several thousand miles without issues. Anyone recommending no tensioner have reasoning behind saying so??
  9. #9 Re: Dampener with double roller
    Feb 2010
    Oklahoma City, OK
    "If a timing chain is not properly tensioned, it may develop slack, which can result in chain-slap and premature fatigue. Cracks in the chain may develop, resulting in failure."
  10. #10 Re: Dampener with double roller
    It's not a timing issue...because that's covered on the tight side of the chain. It's mostly slapping around. I've installed both ways.
  11. #11 Re: Dampener with double roller
    Feb 2010
    Oklahoma City, OK
    I kinda worded that first part wrong but yeah that's why most of what I said was about the slap... I see plenty never have any problems not running a tensioner but I still wonder if those few broken gears and chains I've seen coulda been prevented with a tensioner so I chose to run one because nobody could give me a good reason not to and I had at least 1 reason to run one. And yes I know about the gears that didn't fit right that led to a few breaking.
    Bowie, MD
    So which one was better for you bill?
    Sent from my SGH-T989 using Tapatalk 2
  1. When is a double roller needed?
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2012, 03:49 PM
  2. Should I get a double-roller?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 11:20 AM
  3. which double roller
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 06:52 PM
  4. Timing a double roller?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 06:57 PM
  5. Double roller issues
    Last Post: 05-03-2008, 09:07 AM
