Thread: boost gauge not working
Results 1 to 6 of 6
  1. #1 boost gauge not working
    Dec 2012
    Hamilton,Ontario
    My boost gauge in the drivers info center on my 97 GTP doesnt seem to be working. As well, the previous owner seems to have a needle style boost gauge installed in the lower dash compartment that also doesnt work. Any ideas where I can start?
  2. #2 Re: boost gauge not working
    Look for a broken vacuum line or other vacuum leak.
    Aug 2011
    Kenosha
    Find the vacuum line for the aftermarket boost gauge and check it. I would imagine the dic gets its boost reading from the map sensor. I'd start there.
  4. #4 Re: boost gauge not working
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Most people use a T connector at the evap as it's closest to the firewall. Check for an unplugged or damaged vacuum line right around where I illustrated for you below.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  5. #5 Re: boost gauge not working
    Dec 2012
    Hamilton,Ontario
    Quote Originally Posted by JerzNick View Post
    it was exactly as you said, the line was hanging from there, plugged it in, works perfectly now, thanks alot!
  6. #6 Re: boost gauge not working
    Oct 2012
    New Jersey
  1. boost gauge/meter not working
    By shart in forum General Tech Discussion
    Last Post: 01-28-2012, 06:06 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. Boost Gauge Stopped Working
    By chipsdubbo89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2008, 03:58 PM
