Thread: need info on cam swap
Results 1 to 11 of 11
  1. #1 need info on cam swap
    Aug 2008
    oharr
    Ok so I curentlly found out I need to change my camshaft I have a friend that took Out a 3.8 engine from his camaro now my question is if I can take out his cam and put it into mine I have a 98 gtp ?
  2. #2 Re: need info on cam swap
    Wichita, KS
    Obvious question would be no.
    Why do you need to replace your stock cam shaft anyway? If your going through the effort, at least put something better in. Just my $0.02 on that.
    ~F~
  3. #3 Re: need info on cam swap
    Aug 2008
    oharr
    Well I was gone do a while and my so called" mechanic wiz" brother in law ran it without water and the camshaft gave out before it did it sounded like a diesel truck
  4. #4 Re: need info on cam swap
    Wichita, KS
    Yikes. Never good on a motor. Thats how I bought my car, with a bad motor, and the previous owner did this as well. (drive with no coolant in it) I could put a garden hose in the radiator, and when it got full start the car, and it would poor out of the engine as fast as the water from the hose was going in. Turned out...water pump was waaaaaaaaay gone.
    The lifters/valve train were extremely noisy. When I finally took the engine apart later to build it up from the bottom, it had obviously got very hot by the condition of the parts. Hot enough to seize the motor, and as things cooled, shrunk in size so it was able to run again. bad thing is, the damage was already done. Those parts were toast.
    ~F~
  5. #5 Re: need info on cam swap
    Aug 2008
    oharr
    Man that's nasty ....well hopefully the extent isn't too that point so where did you get all the parts and about how much did everything cost to replace it and get it up and running?
  6. #6 Re: need info on cam swap
    Aug 2008
    oharr
  7. #7 Re: need info on cam swap
    Bastard Reptile's Avatar
    Kansas City, MO
    If it got hot enough that it's knocking....then you're gonna need more than a camshaft.
  8. #8 Re: need info on cam swap
    Reptile is right ...if it got hot enough to make it knock you might have more issues then just the camshaft. Also these motor have roller cams from the factory, they are very hard to damage with just heat..it might be just the lifters that are making all the noise.
  9. #9 Re: need info on cam swap
    Aug 2008
    oharr
    But before it gave out It didn't get hot or anything but we took off the belt to see If the harmonic bslancer would turn to see if it was the cam and it didn't turn at all so what do yall think I'm gonna have to replace to make sure its running right?
  10. #10 Re: need info on cam swap
    Barksdale AFB, LA
    Quote Originally Posted by 98bdgtp View Post
    The whole engine.
    2009 Subaru Impreza WRX STI
  11. #11 Re: need info on cam swap
    Wichita, KS
    ^ sadly X2 I think your brother in law just bought you a new engine.
    You would spend enough time tearing it down to figure out what it needs that it would be worth.
    When I built my engine, I built it to race, and to run with/around nitrous injection. Not cheap to build a race engine by any means, and especially not cheap to build one of ours from a bare block. If you have to ask...its too expensive general rule of thumb. But you can crunch some numbers, and do a little shopping trip from INTENSE-Racing.com - Grand Prix, Bonneville, Regal, L67 3800 Supercharged Performance Products.
    Getting a replacement low mileage engine and swapping it over would be your best bet. You only have about a 40% chance of a shop getting it right the first time where it lasts longer than 20K miles before its dead again if it was rebuilt. A crate engine from Jasper...I'd keep walking as well, stay far away from their stuff IMO. Seriously though...I would give ED a email/call and see what he has in stock. Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    ~F~
  1. Info / Recomendations
    By Apples in forum Turbo
    Last Post: 07-13-2008, 04:42 AM
  2. Oil filter info
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-03-2008, 10:02 AM
  3. old problem but new info
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2008, 12:04 AM
  4. Need Some Info From Everyone
    By GTPon22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 11:05 AM
  5. HID info
    By archemedes in forum Visual/Body Modifications
    Last Post: 02-19-2008, 08:54 PM
