I bought this 98 GTP that had a bad trans. Pulled motor, swapped trans, put the car back to stock. Everything runs fine except:
Air bag light on, cruise doesn't work, steering wheel controls don't light up (or work) and the horn doesn't work.
The brake lights work, wipers, turn signals, brights/headlights work fine.
I thought it might be the turn signal switch in the column. I don't think that's it because everything worked fine before I pulled the motor/trans.
I've checked the fuses and connectors under the dash where the harness plugs in for the switch.
When I pulled the motor/trans I didn't drop the cradle. Everything came out the top and the steering was never disconnected. Before I go to pick n pull to get a switch what else can I check? Grounds? Where?
