Thread: ~7 degrees of KR on 3.5" pulley, please Advise
Results 1 to 20 of 32
  1. #1 ~7 degrees of KR on 3.5" pulley, please Advise
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Alright, so you may or may not remember my posts a month or two ago, but I had headers, AL104's, open cone, stock pulley, stock tune. I used the android torque app, and thoroughly tested for KR. Had 1-2* of part throttle KR, but no WOT KR. I took this as a green light to pulley down.
    Then, I installed a 3.4" pulley on an MPS I bought online (knew I was going to have to settle for a 3.5, but I got a great combo deal) and scanned for KR again. This time, I got 6* of KR at WOT (IAT~90*F, which was of course unacceptable. I purchased a 3.5" pulley from a member on here, and installed it. I drove lightly until today (finally had day off and nice day to scan).
    So today, the air temperature is about 50*F. The IAT was reading +or- 70*F. Remember, stock tune. When I really stomped on it, I was hitting about 6.5* of KR... much worse than I was expecting. It was all during WOT, and at this time I didn't suspect anything is banging around, because I had no KR on stock pulley. I did, however, notice that my coolant temp was about 215*F, which was way higher than I thought it might be... my dial never shows higher than 190ish.
    I plan to use a 180* thermostat from now on, but I only expect that will remove 1 or 2 degrees of KR. The KR is fairly steady, peaks on the shifts but shifts aside I'm getting a good 5* of KR at WOT.
    I was trying to avoid spending money on tuning, but it appears that I might have no other choice. Please, share your thoughts and ideas. Also, is it normal for the engine temperature dial to be friggin 30 degrees off the sensor's reading?
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    only go 180 t-stat if your pcm is tuned for it.
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
    I hope you plan on putting the stock pulley back on ASAP before you chip a piston. Right off the bat I can tell you you don't have enough flow mods to be dropping pulleys just yet. You need some headers or a plog and get rid of those restrictive manifolds. PCM needs to be tuned for a 180tstat throw the stocker back in until you have one.
    I'm going to suggest right off the back you go and read nicks modding sticky.. Your not ready to drop a pulley just yet.
    04 Comp G.
  4. #4 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Sep 2011
    Vancouver
    you could just pulley down. but i think a tune is the most beneficial route. and alot of guys seem to like the idea of a bigger pulley with more added timing
    99 R34 skyline
    What's more expensive a new motor or a tune..in the end having knock is going to kill the motor. A tune is way more beneficial than mods at the moment.
    04 Comp G.
  6. #6 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Knoxville, TN
    Quote Originally Posted by GTP131 View Post
    Redcompg, um, look again?
    Totally missed that part damn you tapatalk. You need a tune guy! Even a mailed order one is better then nothing.
    04 Comp G.
  8. #8 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    You need a tune.
  9. #9 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Ontario
    Don't waste your time with a canned tune. I'd advise you try and find a local to hook you up with a street tune.
    In car tune > canned tune but of course that cost more $$$ and that's if your able to find anybody local that can tune. But if you can't it's not a waste of money getting a canned tune.
    04 Comp G.
  11. #11 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Texas
    Pulley up through the winter then drop pulleys again next summer if you want to take the cheap way out.
    85 Corvette
    01 TA
    03 Z06
  12. #12 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Reminds me of mech's car.
    Just didn't want a smaller pulley. Canned tune or stock.
  13. #13 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Knoxville, TN
    Huh, well this just kind of sucks. I figured with a 3.4" getting 6* of KR, then a 3.5" would be just about there. Does throwing more fuel at it help the issue? Say if I tuned it?
  14. #14 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Not really.
    Added fuel will just be pissing your money away and the car won't go any faster than if it had a larger pulley.
  15. #15 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Knoxville, TN
    Sooo... are you stating that I'll either have to pull a ton of timing or pulley up? Just doesn't seem right with my mods. Will tuning do me any good then?
  16. #16 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Ontario
    Needs a tune. ASAP. I'd go back to stock pulley for the winter, and take it to a shop for a tune. That's just me tho
  17. #17 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    Check and make sure your trans dipstick isn't hitting the header and that your motor mounts are good and not causing the headers to hit the firewall or anything like that.
    Quote Originally Posted by Oxfire View Post
    Me too.
    04 Comp G.
    Or you could pull the belt of the supercharger and enjoy the slowawesomeness
    04 Comp G.
  20. #20 Re: ~7 degrees of KR on 3.5" pulley, please Advise
    I ran untuned on a 3.4 setup and it had less KR then when I switched to my zzp pcm.
