Thread: Total NOOB mistake! (Heads)
Results 1 to 20 of 26
  1. #1 Total NOOB mistake! (Heads)
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    So I sent my heads to be ported and polished... They also cut the heads back to 100% straight.
    Problem is, when they cut them, My markings for front & rear head got wiped out. Now I don't know which one is which.
    They have separate numbers stamped in them, does anyone know which one is which by those numbers?
    P.S. Have been googling this for hours to no avail!
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    They are interchangeable, don't worry about it.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  3. #3 Re: Total NOOB mistake! (Heads)
    I do believe he is correct.
    May 2011
    United States
    Just worry about getting the gaskets on the right way. Arrows to the pass side, thats witb felpros.
    Sent from my Droid
  5. #5 Re: Total NOOB mistake! (Heads)
    Oct 2012
    New Jersey
    Quote Originally Posted by Sushamouf View Post
    But I have the valves, springs, retainers, rockers and push-rods all marked to a specific cylinder on each head.
    Isn't it pretty important to put the valve-train back on the same cyl head?
    May 2011
    United States
    The only thing that the orentiation on all that kind of matters is the valves, which you should be getting re-ground anyway.
    Sent from my Droid
  7. #7 Re: Total NOOB mistake! (Heads)
    Oct 2012
    New Jersey
    I was just about to lap them when I noticed my head markings were gone... If I carefully re-seat with lapping compound, you think it will be ok?
    May 2011
    United States
    You have the heads off, I would just take them back to the machine shop and have them valve-jobbed. Also get the valves back-cut. Lapping is kinda half assing it.
    Sent from my Droid
  9. #9 Re: Total NOOB mistake! (Heads)
    Oct 2012
    New Jersey
    Damn... I was trying to save some $! This sucks!
    May 2011
    United States
    Valve guides are also probably worn. Liners would be a good idea.
    Sent from my Droid
    May 2011
    United States
    Lapping them would prob work, you are just so close to doing it the right way.
    Sent from my Droid
  12. #12 Re: Total NOOB mistake! (Heads)
    Every set of 3800 heads I've ever taken in needed a valve job badly. Do it..smile and enjoy it.
  13. #13 Re: Total NOOB mistake! (Heads)
    Oct 2012
    New Jersey
    Brought them in to my local machine shop, you were absolutely right. They BADLY needed work.
    Now I can smile and enjoy
  14. #14 Re: Total NOOB mistake! (Heads)
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Only the valves, rockers, pushrods, and lifters need to be oriented. If you have new pushrods, you don't need to worry about their orientation and you don't have to worry about that for re-using the lifters (roller only) either. These heads don't have hardened valve seats either. That's why you need a valve job.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  15. #15 Re: Total NOOB mistake! (Heads)
    Oct 2012
    New Jersey
    Thanks for the insight. Heads & valves will be ready for pickup tomorrow. I have new compcam lifters going in after a good soak in oil.
    Curious on how much you spent so far and what all was done?
    04 Comp G.
  17. #17 Re: Total NOOB mistake! (Heads)
    Howell, NJ
    Where in new jersey are you located?
  18. #18 Re: Total NOOB mistake! (Heads)
    Oct 2012
    New Jersey
    $12.50 per valve... Now the guy is telling me I have stress cracks on my valve seats
  19. #19 Re: Total NOOB mistake! (Heads)
    Oct 2012
    New Jersey
    Quote Originally Posted by Jomamma View Post
    Morristown. I see your only 30 minutes away...
  20. #20 Re: Total NOOB mistake! (Heads)
    Howell, NJ
    Quote Originally Posted by JerzNick View Post
    *cough* cough* W Body Store CNC Heads *cough*
    Good to see another jersey member.
  1. 99 gtp...
    By Anthony Smith in forum Members Rides
    Last Post: 07-08-2014, 12:08 PM
  2. An Idoit's Mistake?
    By kjohnson in forum Off Topic Discussion
    Last Post: 08-28-2012, 10:06 AM
  3. paid a guy to put a junkyard engine in my GP...mistake
    By tquarter in forum The Rant Forum
    Last Post: 08-21-2011, 10:18 PM
  4. Headbolt Mistake
    By piperflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-05-2009, 09:01 PM
  5. Made a Mistake
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 02:11 AM
