Thread: Gins data stream
Results 1 to 3 of 3
  1. #1 Gins data stream
    gardner,mass
    Basicly im getting horid gas mileage 10-12mpg and for one i have no cat and 1500 miles im not getting any codes for it.
    i have done everything regarding tune up so i figured someone might be able to point me in the right direction given this data
    Intake air temp 149 degf
    spark 8 deg 4k rpm-30 deg
    air fuel ratio 14.7:1
    maf 4.71 - 18.06 g/s
    map 5.61- 11.52 inHG
    fuel pressure 58psi
    long term fuel trim -4 to 6
    engine load 7-16%
    02s1 0-890 mv
    evap pruge sol 12-62%
    ect sensor 203-214 degf
    ho2s 1 heater .62 amp
    ho2s 2 195-751 mv
    ho2s 2 heater .56-.58 amp
    ignition 1 signal 13.7v
    injector PWM 2.9-3.0 msec
    st fuel trim 1-4 %
    start up coolant 216 degf
    tp angle 1%
    kr at wot 0
    need anything else lmk
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Gins data stream
    gardner,mass
    i was thinking seeing the o2s 1 is reading 0-890 mv that meens there is a short cus it should fluctuate but never go to 0 so i changed the front o2 sensor and so far mpg seem ok but i havnt driven enough for anything to cycle so ima give it the drive to pa and see if my cat code finnally apears and see how my mpg are on the way there all highway
  3. #3 Re: Gins data stream
    You'll never see the o2 mv drop to zero unless you hit the decel fuel cutoff mode.
    It should always bounce around from 50-900ish all the time, and the rear o2 I think will stay around 400-600 if the cat is working correctly, but I'm not 100% sure on that.
  1. New MazdaSpeed3
    By Timing in forum Members Rides
    Last Post: 05-30-2017, 10:47 PM
  2. Uv scan not saving data
    By Z34Phoenix in forum PCM Tuning
    Last Post: 06-28-2011, 01:51 PM
  3. Obd live data ?
    By DC1263 in forum General Tech Discussion
    Last Post: 03-24-2009, 10:42 AM
  4. data bus interface
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 01-14-2009, 01:00 PM
  5. Needing dyno run data with XP cam
    By TDCRacing in forum General Tech Discussion
    Last Post: 11-18-2008, 09:57 PM
